Old 07-16-2013, 08:07 PM   #11
UJOINT's Avatar
Re: New UJoint Project
V5 is a 6" on 35's, 8' is TIGHT with no rack. It fits though
Work continues, I'll post some pics soon. Tranny is 4wd, spring hangers are drilled and currently being coated, shackle sleeves welded in, upper airbag mounts bolted in place, coil buckets cut off and ready for the DS001 mounts, flares on, Onboard air tank & compressor Mag-Hytec pan is holding tons of ATF, axles are going together this week. Moving along!!!!
Engine work is done too! Full 6.0 treatment including a new oil cooler.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-17-2013, 07:08 AM   #12
How's the Cummin's conversion going Chris?
Old 07-17-2013, 07:17 AM   #13
UJOINT's Avatar
It's going! We had to knock out some other things and wait for some special parts so progress has been slow. Back on it now though, just tacked in the motor mounts yesterday.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-20-2013, 01:29 PM   #14
UJOINT's Avatar
Ready for axles.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 07-29-2013, 10:14 AM   #15
UJOINT's Avatar
Sterling 10.5 is in, ready for brake lines once we set the pinion angle. T-case is in too, should have the front axle wrapped up today!
Plumbing up all of the goodies today, OBA, rear airbags and the under dash control, ARB compressor switch, etc.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 08-11-2013, 08:36 AM   #16
We are getting there. It's rolling and driving. Roof rack, early next week. Re-covered and re-stuffed seats, 80HP tune. Just got a new FICM yesterday.
Pick it up this coming Thursday!!!
Jim
Old 08-11-2013, 01:30 PM   #17
Pschitt's Avatar
I saw your van yesterday. Great job done by U-Joint!
Old 08-11-2013, 03:19 PM   #18
UJOINT's Avatar
Here are some more pics----
Fuel tank, OBA compressor, 4" exhaust, air tank.
I'll post some final pics as we finish up this week.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 08-11-2013, 03:21 PM   #19
UJOINT's Avatar
Side shot-- 6" lift, 315/70/17 BFG's on Black Rock wheels. Dual Bilstein 5160's up front, Aluminess F&R. It's hard to tell in this pic but the lower body is coated with Rhino Lining that has been painted body color.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 08-17-2013, 12:59 PM   #20
buckkiller's Avatar
Re: Another adVANture 2006 6.0 Ujoint Build
Another good looking rig Chris...
Buck
The Redneck Mexican
2002 E350 7.3 PSD 4x4 8inch lift pop top conversion....
"The Redneck Mexican"
2002 E350 EB 7.3 Clydesdale 4x4 w/8' lift,
Colorado Camper Van pwr top,
Van Specialties build out
buckkiller is offline   Reply With Quote
Rufus
LARufus
Vanzilla
Glenn P.
