Old 10-19-2023, 03:17 AM   #81
Looks like a fun trip. What will you use for a shower pan?
coloradoup is offline   Reply With Quote
Old 10-19-2023, 03:17 PM   #82
225
225's Avatar
It was fun. Thanks!
The shower pan is based on a Home Depot shower pan. But I will be using a thin layer (1-2") of floor mud, aka mortar base, and then the Oatey Shower floor liner with tile on top of that.
For the walls will be the lightweight Kerdiboard with FRP on the outside.
2014 Ford E-350 SRW Box Truck
1983 Jeep CJ7
225 is offline   Reply With Quote
Old 10-20-2023, 09:42 PM   #83
Looking forward to seeing that. Sounds like what I do for resedential showers. Great work!
Old 10-30-2023, 05:56 PM   #84
h.grenade's Avatar
Looking good! Sounds like a fun trip.
h.grenade is offline   Reply With Quote
Old 01-18-2024, 08:41 PM   #85
225
225's Avatar
I work on a boat, and we're in the shipyard getting our 3 year overhaul. I'm in the parking lot working on the box truck lol.
Here is the shower framed up and mortar bed in to make everything slope towards the drain. There is maybe 1/4" of mortar in half of a 9 sq ft shower.
Insulated, walls are Kerdi Board foam backer board. Shower pan is Oatey shower pan system.
Tile grout drying:
BOOM!
Walls are FRP. I am going to trim every corner with aluminum. Everything is waterproof even before the FRP is up, but I am going to silicone the crap out the trim.
And still some FRP to install.
1983 Jeep CJ7
Old 01-19-2024, 07:37 AM   #86
nyyankees588's Avatar
Very cool job on the shower - I love the stone floor, it's an awesome departure from the standard white FRP/plastic shower pans.
2003 E250 Full Self-Build
2009 Honda Element "lil' toaster"
2013 Suzuki DR650
Santa Cruz, CA
nyyankees588 is offline   Reply With Quote
Old 01-21-2024, 07:48 PM   #87
225
225's Avatar
Thanks! It doesn't add that much weight either. I can't finish trimming it out until I get home, tho.
When the shower is finished, I need to add the gray water tank. After that, I will do all the trim work.
And the final step will be to turn the closet into half closet half drawers. Then I will be done!
On the side I have been collecting parts for 4WD. Once I get the axles built, I will start on that. But that's a next fall project.
1983 Jeep CJ7
Old 01-23-2024, 11:29 PM   #88
h.grenade's Avatar
Shower is looking great 225!
Old 01-24-2024, 09:22 AM   #89
225
225's Avatar
Thanks!
Poop vent and light is in. It doesn't look like much but it took all day. I had to unbolt a solar panel, which is a PITA. Then cut the hole, and chase down a short inside the fan. I'm so ready to be done with this shower lol.
1983 Jeep CJ7
Vantastic
maxx
Campervan
Joerg
