Originally Posted by carringb
If you are willing to trim the van fenders larger, and use a large amount of body filler, you could make it work. It would be messy and take a lot of work. You'd have to crop the fenders are the front doors too, or cut and mount them to door.
I’m seriously considering taking up your challenge, good sir. I have a cut-off wheel, a welder and a hammer, and I’m not afraid to use them! (I’ve also modded plastic snorkels with a heat gun. Maybe that would help?)
The van fenders are crazy expensive, and I’m running 31x10.50x15 Dick Cepek EXPs. Fronts stick out a bit, and I’m hoping to space the backs 1.5” on each side to match front track.
Was actually thinking about these, and if they work then eventually replace them
With equivalent Bushwackers when they crack.
https://www.amazon.com/dp/B07H4HHR5R/?coliid=I550L39NDTRXE&colid=3QEWIJXCN8WHP&psc=1&re f_=lv_ov_lig_dp_it
