Old 08-29-2009, 06:10 PM   #1
blkjak's Avatar
how do you install what generator under a ford van?
"The generator SMB adds to the Fords goes in place of the underfloor storage or factory spare as it were (they are the same place)."
any pics? what mfg generator? fuel supply setup? on/off setup?
thanks ... blkjak
https://pic50.picturetrail.com/VOL165.../392572714.jpg
2005 ford e-250 extended crew cargo van "stealth sleeper".
blkjak is offline   Reply With Quote
Old 08-29-2009, 06:58 PM   #2
Re: how do you install what generator under a ford van?
Fuel supply: Auxiliary Fuel Port
The SMB's I saw in Fresno, and the rescue vehicles sent to Qatar had Onan generators. Onan has underfloor mounting kits for specific models. The generator was mounted right behind the rear axle between the frame rails. It looked a lot further forward than TwoLost's.
Old 08-29-2009, 09:18 PM   #3
Look for photos of Twolost's rig. The big yellow thing under the rear bumper is the generator.
Old 08-30-2009, 07:41 AM   #4
I looked at a built in
Decided against cuz i dont want the whole rig to vibrate and hum
JMHO
Old 08-30-2009, 09:36 AM   #5
Then I hope you're not getting a Norcold...
Old 08-30-2009, 02:12 PM   #6
Truck fridge 4.c cf
same brand as i had in my Westy
THEY ROCK, but are quite ...........
Old 08-30-2009, 05:25 PM   #7
blkjak's Avatar
thanks everyone...for the help...blkjak
Old 08-31-2009, 10:11 AM   #8
JMHO
It doesn't. Vibration is really not noticeable and the humming inside, is not intrusive and doesn't require you to raise your voice to maintain a normal conversation.
Outside is a different story altogether. Loud enough that I try to park away from neighbors to avoid bothering them. I don't understand why they don't fit these things with a muffler.
I tried to take some pictures of the generator under my van, but the lighting just isn't there for the pictures to work. The doc's posted by J.Whitbread are probably better and more descriptive than anything I could have come up with anyway...
sailquik is offline   Reply With Quote
Old 08-31-2009, 11:53 AM   #9
So who removed the undervan tire carrier? SMB? or did the vans come without one?
Tom
Austin, Texas
1995 SMB E250
Old 08-31-2009, 12:26 PM   #10
SMB removed the existing undercarriage tire carrier and installed the genset and an Aluminess tire carrier in the rear.
