Old 08-21-2018, 12:12 PM   #1
BenJJ's Avatar
Junkyard Fixed Top
Spotted this EB fixed top on a van at the LKQ in Anaheim. People have been looking for these in the past so thought someone might be interested in going and grabbing it. I think the yard would charge somewhere between $100-$150 for it. No idea how hard they are to take off.
BenJJ is offline   Reply With Quote
Old 08-21-2018, 12:14 PM   #2
Youngster's Avatar
....and a FF axle too!
2016 Beta 500 RS
2014 KTM 350 EXC-F
Youngster is offline   Reply With Quote
Old 08-21-2018, 04:07 PM   #3
And a V10!
Old 08-21-2018, 05:37 PM   #4
MountainBikeRoamer's Avatar
I'm not buying at the moment, but I'd just be curious to see how much $$$ LKQ asks for that rear FF.
Mike T
___________________
'95 Ford E250 RB30 PH
Old 08-22-2018, 09:12 AM   #5
longboardguy's Avatar
from the price list:
Axle Assy, Truck D To D $154.74 +$35.00 core
2006 e350 EB Quigley V10 Gas Daily Driver
Fiberine 24" high top
Home Build interior, 200w solar, 42 Gal fresh water
46 gal Transferflow tank, Agile RIP kit
longboardguy is offline   Reply With Quote
Old 08-22-2018, 09:14 AM   #6
shadetreevanman's Avatar
LKQ charges $70 for the top.
Tim Potts
Old 08-22-2018, 02:37 PM   #7
Oh man, that is a STEAL!
Knowledgeable wrecking yards are getting $1,000+ for those....
Wish I could jump on that.....
Mike T
___________________
Old 08-22-2018, 04:42 PM   #8
shenrie's Avatar
What year did eseries start getting rear disc brakes?
Old 08-22-2018, 06:18 PM   #9
'99
The message you have entered is too short. Please lengthen your message to at least 10 characters.
Old 08-22-2018, 07:17 PM   #10
Note of caution:
Be careful when shopping for a rear FF --- you also need to be aware of what style rear ABS sensor setup your current axle has if you're upgrading.
From what I understand:
Even though they will all have rear disc brakes after '99 as carringb noted, there's a significant difference in the ABS/speed sensor setup on different years.
Axles from '99 through around '04 (or so?) use a single rear ABS/speed sensor (mounted to the differential), but axles newer than that use a two-sensor setup (one at each outboard end of the axle.)
Ya might have some ABS/speedo compatibility (and trouble code) issues if you mate up a different-sensor-layout-axle to your rig.
Mike T
___________________
