08-21-2018, 12:12 PM
Junkyard Fixed Top
Spotted this EB fixed top on a van at the LKQ in Anaheim. People have been looking for these in the past so thought someone might be interested in going and grabbing it. I think the yard would charge somewhere between $100-$150 for it. No idea how hard they are to take off.
08-21-2018, 12:14 PM
....and a FF axle too!
2016 Beta 500 RS
2014 KTM 350 EXC-F
08-21-2018, 04:07 PM
And a V10!
08-21-2018, 05:37 PM
I'm not buying at the moment, but I'd just be curious to see how much $$$ LKQ asks for that rear FF.
Mike T
___________________
'95 Ford E250 RB30 PH
08-22-2018, 09:12 AM
from the price list:
Axle Assy, Truck D To D $154.74 +$35.00 core
2006 e350 EB Quigley V10 Gas Daily Driver
Fiberine 24" high top
Home Build interior, 200w solar, 42 Gal fresh water
46 gal Transferflow tank, Agile RIP kit
08-22-2018, 09:14 AM
LKQ charges $70 for the top.
Tim Potts
08-22-2018, 02:37 PM
Oh man, that is a STEAL!
Knowledgeable wrecking yards are getting $1,000+ for those....
Wish I could jump on that.....
Mike T
___________________
08-22-2018, 04:42 PM
What year did eseries start getting rear disc brakes?
08-22-2018, 06:18 PM
'99
The message you have entered is too short. Please lengthen your message to at least 10 characters.
08-22-2018, 07:17 PM
Note of caution:
Be careful when shopping for a rear FF --- you also need to be aware of what style rear ABS sensor setup your current axle has if you're upgrading.
From what I understand:
Even though they will all have rear disc brakes after '99 as carringb noted, there's a significant difference in the ABS/speed sensor setup on different years.
Axles from '99 through around '04 (or so?) use a single rear ABS/speed sensor (mounted to the differential), but axles newer than that use a two-sensor setup (one at each outboard end of the axle.)
Ya might have some ABS/speedo compatibility (and trouble code) issues if you mate up a different-sensor-layout-axle to your rig.
Mike T
___________________
