Old 07-17-2019, 10:59 AM   #11
b. rock's Avatar
Was thinking of a high top with an extending bed before we switched to the pop top route. Our plan was to use interlocking pieces of wood to act as a slide. This being the motivation: https://gnomadhome.com/diy-van-build-pullout-bed-frame/
Are you planning on having any rear drawers or putting the mtbs on a slide?
b. rock is offline   Reply With Quote
Old 07-17-2019, 11:08 AM   #12
Yes the mtb slide is done. I'll be taking out the seatpost/saddles so that I get a few more inches of headroom. I've also put up new wall paneling over the exiting utility ply. The bed build is delayed until I'm back from EAA Oshkosh in a couple weeks.
1998 E350 7.3 Hightop
r27d is offline   Reply With Quote
Old 07-17-2019, 11:12 AM   #13
The silicone between my 3 month old fiberine top and windshield is peeling already. Should i just trim it? there's another 4" of silicone under the flange.
Old 07-17-2019, 11:15 AM   #14
Oly11's Avatar
Does Fiberine recommend a specific adhesive for mounting the top?
Oly11 is offline   Reply With Quote
Old 07-17-2019, 11:17 AM   #15
Fiberine did the install and they used CR Lawrence Silicone Sealant 33S.
Old 07-26-2019, 01:29 AM   #16
I used a polyurethane caulking/adhesive by “Sikaflex” - on my high top and it bonds well to the paint if it is sanded first and cleaned off before applying the caulking. It comes in basic colors like white, grey, black, tan, etc...
2006 RB E250 Ford High top, Diesel 6.0 Bullet Proofed (ouch $) 4" Camburg Eng. Lift, Method Wheels, 33" Toyo AT, RB50 interior (homebuilt)
upsidedown is offline   Reply With Quote
Old 07-26-2019, 09:02 AM   #17
shadetreevanman's Avatar
Silicone does not weather well in direct sunlight. Not sure why any professional would have used silicone for your application.
I used Sikaflex 521 UV Resistant LM Polyurethane Sealant to caulk the perimeter of the top after installing it.
Sikaflex 221 Adhesive was used to glue the top to the roof of the van.
Tim Potts
Old 08-06-2019, 01:09 PM   #18
jjbusch's Avatar
I self installed my 30" camper top. At the recommendation of Fiberine, I used silicone between the flange and the roof, and (my own decision) used loctite pl marine polyurethane sealant around the edge.
After 20k miles of rather abusive travel around South America, the top remains well sealed.
-jeff
jjbusch is offline   Reply With Quote
Old 08-26-2019, 07:07 PM   #19
Starting to get some more projects done. I did the grab handle install that Hammerhome wrote up. I figured out how to use albums here but the rotation is meesed up now http://www.sportsmobileforum.com/for...-up-12665.html
Old 08-27-2019, 08:59 AM   #20
Wickedwagens's Avatar
We did the bed over storage, but supported from the floor not the sides. How high do you need to clear the bikes?
Wickedwagens is offline   Reply With Quote
