Old 02-19-2015, 01:51 AM   #1
Bee
Road Block
Anyone know how to remove these E-Track liners? I'm trying to remove all the paneling and I've pulled all the plastic fasteners but these tracks in the center on each side of the van are bolted in and don't have a screw head to remove them...
Bee is offline   Reply With Quote
Old 02-19-2015, 02:36 AM   #2
Karsten's Avatar
Re: Road Block
Looks like rivets to me, so a good drill is your friend here.
'98 E-250 5.4 2WD Cargo Van
Karsten is offline   Reply With Quote
Old 02-19-2015, 04:26 AM   #3
Re: Road Block
those are indeed pop rivets, steel bodies and a very hard center mandrel.
In order to remove them first use a center punch and drive the mandrel inward, exposing a hole. Make sure the mandrel is all the way out of the rivet body, not just slightly below the surface.
With a sharp 9/32" or 5/16" bit drill squarely into the rivet body, just deep enough to remove as much of the rivet head as possible. Do this along the bottom of the E-Track first before moving to the upper side.
On the upper row remove all rivets this way leaving the center one for last. This way it won't fall or slip lose unexpectedly.
HTH
Old 02-19-2015, 05:35 AM   #4
E350's Avatar
Re: Road Block
Why remove them. Just cover the up with your insulation and move forward.
Old 02-19-2015, 10:06 AM   #5
Bee
Re: Road Block
Those e-tracks are keeping me from removing those grey plastic wall liners. I'm trying trying to get the van gutted down to the metal.
Old 02-19-2015, 10:10 AM   #6
Bee
Re: Road Block
HTH
Sounds like you know what you're talking about. All those words are beyond my internal dictionary so this weekend when I have time off, I'm going to look up what you're talking about and hopefully have at it with good results. Thanks.
Old 02-19-2015, 10:50 AM   #7
E350's Avatar
Re: Road Block
Got it. Time to use or to acquire new tools!
1. Eye goggles and a face shield from Harbor Freight ("H.F.").
2. H.F. welding gloves (3 pack suede with gauntlets)
3. Makita (not H.F.) 4.5" (not 4") Angle Grinder
4. 4.5" grinding and cutting wheel packet from H.F.
It is the top "flange" on the rivet that is keeping the track on. The above tools will make quick work of this. Grind off the flange and the track should peel off then you should be able to remove the plastic panel and then push the rivets back into the van wall's vertical studs (where they will vibrate forever if you listen closely).
Old 02-19-2015, 12:35 PM   #8
JackTuppVan's Avatar
Re: Road Block
REFERENCE
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 02-19-2015, 02:03 PM   #9
Bee
Re: Road Block
Originally Posted by JackTuppVan
REFERENCE
Thanks for that picture. That makes my brain process what's in there better.
Old 02-19-2015, 03:15 PM   #10
TheYeti's Avatar
Re: Road Block
Just drill em out, takes a little bit, a fresh metal drill bit helps speed it up but its still kinda tedious. If your going to re-attach I highly recommend a pneumatic gun over the manual. Just did this myself not too long ago.
TheYeti is offline   Reply With Quote
Clyde
ormtnbiker
PolarVan
PolarVan
