Old 05-09-2012, 08:02 AM   #1
Stuff Sliding Around
I need some advice on how to set the back of my van up for travel so my Action Packers/Totes don't slide around. I want to load the totes between the storage boxes but need to prevent them from sliding forward. I would rather not do anything that is permanent or difficult to remove so its not in the way once in camp. Thoughts? Here is a pic of what I have so far:
2horsegarage is offline   Reply With Quote
Old 05-09-2012, 08:08 AM   #2
twogone's Avatar
Re: Stuff Sliding Around
Nets will stop 'em from dislodging and bangin' on your head in an emergency.
The "not fuzzy" part of self-adhesive velcro strips will sort of stick 'em to the carpet for normal no-slide travel, I'm guessing
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 05-09-2012, 08:34 AM   #3
Gnarvan's Avatar
I use a cargo net to keep things under the bed in my van. In your case one strap run across the bed frame about mid height on the packers would work. You could use something like these low profile strap loops to attatch the strap on each side of the bed. I'm a big fan of the 1" cam buckle strap.
http://www.aerostich.com/packing-it-in/ ... ops-4.html
This is a picture of the rear cargo net I had someone with an industrial sewing machine make for me. I have a similar one attatched to the bed frame in the front. The funky looking netting in the picture is there to keep pillows from falling down to floor level.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 05-09-2012, 08:38 AM   #4
Thanks. I guess I could just run a couple of webbing straps and buckles across the front.... Or a net. Easy enough to undo and move out of the way.
Old 05-09-2012, 09:18 AM   #5
Advanturetrek's Avatar
Nice nets, by the way.
Anyway, I flush mounted VersaTie Track on my floor. Now, I can put tie downs in a number of places, relocate those tie downs easily, and even remove them when unneeded. I'm still experimenting with some combination of webbing and nets attached to these tie downs.
The Yeti: SMB 4x4 Ford EB, super camper top, RVI interior build
https://www.advanturetrek.com
https://www.facebook.com/AdvantureTrek
Advanturetrek is offline   Reply With Quote
Old 05-09-2012, 09:46 AM   #6
Gnarvan's Avatar
One more tip on securing stuff from becoming torpedoes. You can use a carabiner to attatch things to the drivers side of the cargo strap/net. I use a biner to connect the handle of an ice chest to the cargo net. Nice easy quick disconnect system.
John
Old 05-09-2012, 11:12 AM   #7
I use Raingler netting secured with footmans loops.
tomesd is offline   Reply With Quote
Old 05-09-2012, 01:28 PM   #8
dhally's Avatar
www.strapworks.com
They can make custom nets and sell the footman loops and cam buckles.
2009 E250 RB 5.4L "SilVan"
Old 05-09-2012, 06:10 PM   #9
Noooo.... you'll wind up with adhesive all over the carpet and stains ground into the adhesive, etc. It's a bad mix and doesn't work.
I second the cargo net- either a truckbed net or an elastic cargo net. I prefer elastic cargo because you can step over it, push it down etc and won't get hurt on it. The advantage to a truckbed cargo net would be less give, so your stuff doesn't shift (as it might in the elastic version).
You could also do a truckbed cargo bar between the benches. Fully adjustable, removable and no mount points to install.
Old 05-09-2012, 07:08 PM   #10
cygvan's Avatar
perhaps some web strapping (like the kind on laptop cases and bags etc) ?
could rivet on length to each box you got there and when you connect them it forms a barrier.
i would look for those things that click together that also allow you to adjust tension....like dont know what they are called but this looks like a likely site that has something handy...
http://www.strapworks.com/default.asp
Red Zeppelin - 2003 Chevy Express 2500 6.0L 2WD RB
cygvan is offline   Reply With Quote
