Spent a productive rainy day with the twins!!!
Got the roof frame caulked then bolted down..pulled the roof tin off and got it bent on the sides and the last of the roof tin bolts sealed and installed....ran into a snag on my roof lift design so I've gotta do more research and design work...
So...
We cleaned everything up...got the carpet down..(waiting to put trim in till after all the power has been run for kids Usb ports..)
THEN...we decided to go ahead and build the benches..the passenger side has a slide platform (side braces need installed) it will get large port holes cut in the top so you can access,the inside for a HUGE storage area....the driver side will have a hinged lid and will be mechanical space...battery solar water tool storage...
Passenger side will have the fridge..
Part of why I didn't go with longer benches is so we can still haul animal crates in the back as we foster mini pigs and I often haul them too and fro....and we can load all our camping bins and kitchen in the back untill we get the rear kitchen box..
Sent from my VS987 using Tapatalk
