Old 06-22-2012, 01:31 PM   #1
Coolant leaking between engine and tranny
So my 05 SMB 6.0 PSD is leaking coolant between the engine and tranny (or at least it looks that way). What might that be? Dealer needs to do $300 labor to findout what the problem is. Anyone have a similar problem before? I did notice that the AC wasn't working that well a week ago.
bridges is offline   Reply With Quote
Old 06-22-2012, 02:31 PM   #2
Re: Coolant leaking between engine and tranny
Might be your heater core.
Old 06-22-2012, 05:20 PM   #3
BIGVANS's Avatar
Check the EGR cooler hose first.(EGR cooler to the oil cooler) Then all the coolant hose clamps, they leak some times. May be a freeze plug, may be a head gasket leak at the back.
The pickup trucks have a hose going over the top of the engine to the heater core that rubs through some times???
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-22-2012, 05:57 PM   #4
Ultrasport12's Avatar
If the van has rear heat those lines go over the engine as well.
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 06-22-2012, 06:06 PM   #5
BIGVANS's Avatar
For the Diesel guys, you may or may not have seen this Cooling system PDF before, with some great info. in it. It’s been floating around for a while now so the only author credits I know of are on the last page.
File Type: pdf Powerstroke Cooling System Flush v1-0.pdf (2.08 MB, 32 views)
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-25-2012, 04:40 PM   #6
Can't believe I'm happy that it only the rear heater line. $650 fix. Good news, I guess. Bad news is that the part is backordered with an unknown delivery date.
Old 06-25-2012, 05:10 PM   #7
Could it be spliced with a hose or a large compression fitting?
My bet it it wore through by touching something they are not very strong.
Someone recently posted a picture of where theirs was worn almost through.
They are just thin aluminum pipes with a few hose connections here and there for vibration and flexibility.
Its not high pressure or anything. You could cut out the bad section and slightly flare the ends to help it stay together, install a piece of heater hose (silicone would be best) and two clamps.
2004 F-350 Dana 60
Old 08-10-2012, 09:07 AM   #8
Fishbrain's Avatar
Just had this happen to me...but I had a different situation, so I thought I might add.
I too was leaking a fair amount of coolant, and first thought it was the radiator. But then after pressure testing the radiator overnight, there were no leaks. So we couldn't get it to leak when we wanted it to in order to find where the leak was coming from.
To make a long story short, it turns out it was the water pump. The water pump can "pass" a pressure test if it's beginning to fail. And it can leak coolant in a random pattern till it just ultimately fails.
Just wanted to add that experience....
Fishbrain is offline   Reply With Quote
