Dual alternator
First off I am looking for the lower alternator bracket to move my alternator lower to gain some more room on top of the motor by removing the upper mount...7.3
If you have the dual set up does the ecm controls the second alternator?Is so can the lead from the pcm be removed then excite the alternator to charge a house battery set up. How would you excite the second alternator and what would have to be done with the wire that used to excite....just delete?
