Old 05-09-2022, 06:11 PM   #151
Twoxentrix's Avatar
Precisely why I keep my SMB manual in the Van as a resource... in case I'm faced with repairs on Frankenstein's automotive equivalent.
Old 05-09-2022, 06:31 PM   #152
lol
I get it. I drag my FSM with me (all three volumes). I’m too cheap to rely on the CD option (FSM), plus the tactile part of Holding a manual engages me more
1DogRescuer is offline   Reply With Quote
Old 05-09-2022, 07:08 PM   #153
BrianW's Avatar
When I did the upgrade on my 1998 I reused the ABS sensors from my original front end instead of the ones from the upgraded (newer) parts.
Old 05-09-2022, 07:42 PM   #154
Same here, because QuadVan kept the sensors for the 4x4 axle, but very possible they were not the same anyways.
Old 05-09-2022, 08:13 PM   #155
Thumbs up
Certainly Easy enough to try (both)
Old 05-09-2022, 09:22 PM   #156
I have spent the evening doing a little “recon”. I looked through my Receipts and determined that I Definitely installed new Motorcraft Sensors for ‘08 … you know, to ‘go’ with ‘08 Rotors.
Checked every Cross Reference / Supercede / Substitute reference in my lists of resources. They do Not interchange … at all.
So, the (‘03) PCM for ABS might be calibrated differently/needs (different) signal. This leaves my obvious (?) next step: to order ‘03 and try them. If it changes nothing, the Issue is elsewhere, and I flushed $100.
Lessons learned are seldom Free
Old 05-10-2022, 02:54 AM   #157
Originally Posted by racer_rr View Post
Well shit its been like 18 months and no one has kicked JWA in the balls on this post. I will.
HUGH thanks for JWA for the page-1 2013 post with complete Bill of Materials! I read pg1 through pg3 like 10x.
Thanks BrianW. Can you please elaborate what the issues are and what sources say there is with the 2005 OEM Alcoa rims and 2008 brakes? I didnt come across this in this thread or anywhere. The caliper appear just as tight to the steel OEM rim pix on page-8.
I'm very happy you two found this post helpful---that's quite gratifying and the very reason I put that effort out!
Thankfully the questions outside the intended scope have mostly subsided so we're back to discussing (mostly) just this particular modification or upgrade.
99 Ford
dogredsurf
Guster
Salmon
