Old 06-13-2012, 09:40 AM   #1
EGT and Tran Gauge Install
I finally got around to installing an exhaust gas temperature and transmission temperature gauge. I know that the best place to mount these things is right in your face on the A-pillar. But being vertically challenged, I didn't want to give-up the grab rail that I use every time I get in and out of the van. So I mounted them here.
I think it looks very stock and I can clearly see them while driving, thanks to that dip in the steering wheel airbag / horn unit.
The gauges came with those ring / collar that I had to slightly modify to get the angle and contour right. Her is where I got them; http://www.glowshiftdirect.com/Black-7- ... Gauge.aspx
Drove out to Utah and on the way the outside temp got up to 109, my EGTs never went over 800 and mostly stayed around 600 to 700. The tran never went over 200 and stayed mostly around 180. That's good, right?
I'm going to by installing a 4" turbo back exhaust in the next few week so it will be interesting to see what difference that will make.
Cheers,
John
Old 06-13-2012, 12:21 PM   #2
Re: EGT and Tran Gauge Install
Oooh...
I like that that location and the mounting bezels! I'm out of pillar pod space. I need to add a Tach, and will probably upgrade to a VIAIR setup with supply tank gauge at some point.
Old 06-13-2012, 12:51 PM   #3
BIGVANS's Avatar
NICE!!!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-13-2012, 01:31 PM   #4
Don't know if this mount will fit on a van or not, especially with the SMB overhead storage unit, but I really like the location of my gauge mount in my Excursion. In my sight line with a quick glance, and it also does a good job blocking the evening sun that always seems to be just above the rear view mirror where the visors can't get to.
Old 06-13-2012, 02:22 PM   #5
NEAT...looks really good. I like both types listing in this thread. Gene Atl.Beach
07,E350 custom,smb4x4,e/ph,extrAir,Amsoil
Gene Atl.Beach is offline   Reply With Quote
Old 06-13-2012, 11:32 PM   #6
Thanks all,
Herb, I did consider that location but the sun visors would have gotten in the way.
carringb, sounds like you have a lot of gauges! I have some catching up to do.
Cheers,
John
Old 06-17-2012, 05:14 PM   #7
I put mine where Herbs are:
They are made by auto meter and have several color schemes but turn red when they reach a danger limit.
Old 06-17-2012, 07:10 PM   #8
BIGVANS's Avatar
I love it! Warning, Warning!
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-21-2012, 08:47 AM   #9
Very nice! Yep, Dash mounting space is very limited and strange on Ford vans, especially the newer ones with the rounder dashes. It's like Ford took a huge space and said How can we lay things out where they can't add ANYTHING?!!!!!
My Van
bfolens
Dusty
capnkurt
