Old 01-24-2012, 06:32 PM   #1
Gear Ratio
Quick question. If you change your gear ratio in your diffs.
Do you have to re program the computer for the new ratio?
BMWBILO is offline   Reply With Quote
Old 01-24-2012, 07:10 PM   #2
Re: Gear Ratio
Only if you want the speedo to be accurate and the trans to shift properly.
Old 01-24-2012, 09:25 PM   #3
Re: Gear Ratio
Is that hard to do? I have a 1999 E350 with a 7.3 Powerstroke.
The gear ratio in it now is 3.55.
Old 01-24-2012, 10:58 PM   #4
vandiesel's Avatar
Gear Ratio
I thought it was a matter of using my chip tuner tool but John at Quadvan mentioned a re-gearing of some sort by a speedo shop nearby. Does anyone know the difference? Mine is off by 3-4 mph and my shifting seems way off. I went from a 31" tire to a 34" tire and have 4:10 gears. I'm planning on 4:56 but until then I'd like to at least have things kosher with the speedometer and transmission. I mainly want to make sure the tuner tool does the right thing since it has that feature.
Brad
Old 01-28-2012, 08:37 AM   #5
SheepShagger's Avatar
Re: Gear Ratio
The 6.0 and most 7.3's can be done by any Ford dealer with the right ECU tool, or by some aftermarket tuners.
Autoenginuity software will re-program some ford speedos in the exact same manor as the Ford ECU tools. (IE, no new tune/ECU program) Last time I checked (~2years ago) they only supported the 6.0 on the truck, not van, not sure on the 7.3
Have no idea on the Gas engines.
I did find a thread somewhere that described a process where some 7.3 owners had done it by following some simple instructions found on the net. But I can;t find it now.
It was something like shorting 2 pins under the dash, then pressing the odo buttons to get into some programming mode. This apparently worked on a particular a ford speedo module that they put on a number of different models, all pre ABS I believe. Might be worth a few hours searching.
ClifFord
EliMakes
The YURT
MKRyan
