Old 04-05-2019, 11:43 AM   #21
Originally Posted by arctictraveller View Post
I've always wondered about low temp thermostats. They open sooner as the engine warms, but then you still have the exact same amount of heat rejection as before, so how do they make an engine run cooler once it's open? It might take slightly longer to reach full temp, but I don't understand how they could reduce the operating temp once open.
This battle has been going on for years on some of the diesel forums, sort of like the gas vs diesel threads here.
Old 04-16-2019, 06:33 PM   #22
Today 4-16 I finally got Bigly van back in my possession. Through a comedy of I am not around or the shop owner (small shop) wasn't around we finally hooked up.
New steel impeller water pump
New low temp thermostat
Degas bottle cap
4 part coolant flush and new ELC coolant added
Per Dusty, he had to run the heck out of it or should I say he wanted to run the heck out of it to make sure all was good. All cooling systems normal now and running what would be considered normal for a 6L engine.
There was a piece of rubber holding the T-stat open which explains the lower engine temps prior to the stock water pump breaking. Now seeing high 190-212 fish with some smaller hills.
The upside to this is that he is a whiz with these engines and runs a trucking/shipper support business for clients that love the 6L when properly maintained/rebuilt. He stated that mine was one of the strongest feeling engines he has had the pleasure of driving. Should be as I deleted the EGR and added a coolant filter when I bought it at 13k. Did the Blue Spring then as well and all systems are go.
Looks like a Moab run after the Jeepers leave Moab and try to just get away from all this snow - still. Thanks for input from the inmates on this forum.
Old 04-16-2019, 06:54 PM   #23
Twoxentrix's Avatar
Always a sigh of relief when you're able to manage the Temp's, this inmate felt paroled as soon as I got a handle on mine thanks to many that responded with advise/suggestions from prior posts such as yours - This forum is populated with many contributors providing valuable knowledge. Glad everything worked out for you.
