Old 06-02-2011, 04:20 PM   #21
stikine's Avatar
Re: Rear axle ID
Had a question, I have the 4.1 LS rear axle also (believe it to be the Dana 60) but I see no drain for the rear differential, only the fill hole. Any advice on how to change the oil? Do you have to try and pump it out? Kinda tight back there with my battery and storage box limiting the room.
2007 SMB White 4x4 RB50 6.0l Diesel PH, Toyo 295/70/17 M/T E
https://www.ecotonephoto.com/
stikine is offline   Reply With Quote
Old 06-02-2011, 04:24 PM   #22
Re: Rear axle ID
A handheld suction gun with a 12" - 18" tube. Maybe something like $20- $30 bucks.
Old 06-02-2011, 07:05 PM   #23
Re: Rear axle ID
Take the cover off, clean out the grunge, put cover back on and fill with lube???
Bill
NO2B
Old 06-03-2011, 08:00 AM   #24
Silver350's Avatar
Re: Rear axle ID
Pull the cover. Use RTV Silicone to make a gasket when putting it together. Follow the directions on the tube. Piece of cake.
Old 06-03-2011, 09:10 AM   #25
scatter's Avatar
Re: Rear axle ID
Yup, pull the cover. There'll be lots of grunge in the bottom you'll want to muck out of there. A suction pump won't get it all. Good opportunity to look at the wear pattern on the gears too.
Scatter
2007 RB50, 6.0
K1WGB
MoMo
skyrat
The Beast
IcyDeathPunch
