Old 10-31-2013, 09:40 AM   #1
Tapatio's Avatar
Rear differential oil level with ARB locker
Checked my rear differential gear oil last weekend and noticed that it was about 1/2" below the filler so I filled it back up (even with the filler hole on level ground). After driving it for the past few days I noticed a substantial amount of oil has squirted out of the breather tube. ARB's instructions say that it should be filled "level with the filler hole". Is it because the ARB differential is larger than stock and therefor has a larger displacement? Not really concerned since it will fix itself, curious if anyone else has had this issue.
Stock Dana 60
http://store.arbusa.com/Assets/PDF/RD21_i.pdf
Callsign KK6GIY
Old 10-31-2013, 07:33 PM   #2
UJOINT's Avatar
Re: Rear differential oil level with ARB locker
Do you still have the stock cover? Make sure there's no way the compressor is on and possibly pressurizing the axle.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
Old 10-31-2013, 10:21 PM   #3
My Bronco's ARB solenoid vents some oil when de-energizing. Think it's from a twisted seal in the diff. You might want to check your solenoid.
Old 11-01-2013, 11:09 AM   #4
Tapatio's Avatar
No, I replaced it with a Dynatrac cover. The instructions that came with it said to fill it level. I still have the stock cover, I'll compare them and see if there is a difference in height.
Callsign KK6GIY
Old 11-03-2013, 05:59 PM   #5
The rear end shop I deal with told me they will spit oil if you fill to the level ARB recommends. Don't know how true that is. I just ran the breathers up higher and have never had that issue. I like em higher anyway.
Old 11-04-2013, 07:47 AM   #6
scatter's Avatar
When I put a Dynatrac cover on mine and filled to the bottom of the threads it also blew fluid out the breather. Even with an extended tube. I checked the two covers and found that the Dynatrac one had its filler hole a half inch higher than the Ford one. Seems a dumb move on Dynatracs part, but I just fill to a half inch low and all is well.
Scatter
2007 RB50, 6.0
K1WGB
Old 11-04-2013, 08:23 AM   #7
Tapatio's Avatar
Yep, they put the hole a little higher. It should be done spitting 85w-140 in a few days. What a mess.....
Callsign KK6GIY
