Old 07-16-2012, 04:58 PM   #1
Zeta's Avatar
The Full Badger
Since my transmission coolers and under bumper scoop were so successful--see my award winning expose: viewtopic.php?f=39&t=8542--I may have gotten a bit cocky. I've gone the full Badger(trek) on my rig in the hopes of getting it to run cooler. I added some large hood vents to get hot air out of the engine compartment and some cool side vents others have used. We shall see...
The hood vents are these: http://www.hoodlouvers.com/products.html
They are high quality and conform to the shape of the hood, plus they supplied black rivets which look better IMO. Since the hoods are double thickness, I used a white urethane adhesive to glue the inner and outer layers together where I made the cuts.
Z
'06 RB50 SMB Diesel
https://www.tomsinclair.net
Old 07-16-2012, 05:48 PM   #2
CascadeWalnut's Avatar
Re: The Full Badger
What is the auxiliary antenna coming out of your hood ornament used for?
Matt
2009 Modified RB21 E350 4X4 6.0L Diesel
CascadeWalnut is offline   Reply With Quote
Old 07-16-2012, 06:31 PM   #3
Re: The Full Badger
Matt
If you look in the previous picture that aux antenna is not there. Looks like a rod of some sort leaning against the door frame. Funny juxtaposition!
Pat
PatO is offline   Reply With Quote
Old 07-16-2012, 08:19 PM   #4
Re: The Full Badger
He's a professional photographer and likes to fool people…I’m sure he did it on purpose
He doesn't even have a van...it's all photoshop
Old 07-16-2012, 08:41 PM   #5
SMoaB's Avatar
Re: The Full Badger
I don't know if he even exists. If he doesn't, we'll have to invent him.
SMoaB is offline   Reply With Quote
Old 07-17-2012, 02:08 PM   #6
Tapatio's Avatar
Re: The Full Badger
Curious to see if it helps. Test it by running a stretch of highway with the vents open and then do it again with them taped shut?
Callsign KK6GIY
Old 07-17-2012, 02:14 PM   #7
Gnarvan's Avatar
Re: The Full Badger
Are the hood vents designed to keep water out?
Water=grief if it keeps dripping on top of the engine.
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 07-17-2012, 02:42 PM   #8
Zeta's Avatar
The Full Badger
They're not over the engine.
Z
http://www.tomsinclair.net
'06 RB50 SMB Diesel
Old 07-17-2012, 03:41 PM   #9
Gnarvan's Avatar
Re: The Full Badger
Z
Good point.
Now that I think about it, I can see the vents are more to the front of the engine. I can see the cooling advantages of having a constant drip of water hitting your fan blades. It would create a fine mist inside your engine compartment and the effects of evaporitve cooling should lower engine compartment temps. Keeping things wet inside the engine compartment would also keep dust from building up in your alternator. I bet a damp serpentine belt would also be less prone to squeeking.
John
Old 07-17-2012, 04:04 PM   #10
Zeta's Avatar
Re: The Full Badger
I don't think much water will get in there while moving--the louvers are aimed towards the windshield. Maybe some when it's sitting.
Z
'06 RB50 SMB Diesel
Big Mable
Fikeadelic
Van22
Van22
