04-11-2018, 08:56 AM
#21
Buttpuckerometer? Measures BPPM's. Butt puckers per minute. Pictures of those totaled Powerstops above would certainly cause me to have high BPPM's.
04-11-2018, 11:15 AM
#22
Well, I can tell that another viewer of this thread is from North Carolina. I just found two posts on Craig,s List Raleigh for the Z23 PowerStop rotors and I haven't put mine up there yet.
04-11-2018, 11:38 AM
#23
You know, there may be no problems with the rotors you have. Rather than selling at a loss, why not install them and monitor? Should they turn to rust buckets like mine, Powerstop will probably replace them with something else (it took a bit of "discussion" but in the end they agreed) I didn't mean to trash Powerstop based only on what may be just one bad batch. Plenty of people are very happy with the improved performance.
04-11-2018, 12:46 PM
#24
I sent the vendor an email to see if they will exchange the rotors from the rotor/caliper kit I purchased. I may end up using them, but I really want to get the van in good condition so I can concentrate on the interior build. I only want to do this once, but may have to spend additional time and effort replacing the axle dust shields at the inboard of the knuckle. I haven't been able to take off the rotors yet, but will try the tips I have seen here and on you tube.
04-11-2018, 01:30 PM
#25
Before and after photos
New rotors are on.
04-12-2018, 05:52 AM
#26
My Motorcraft rotors will be here on Saturday. Now if I can just find another way to get the old rotors off. I've watched several you tube videos, but no luck so far.
04-13-2018, 08:34 AM
#27
Lots of PB blaster and a big f'n hammer.
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
04-13-2018, 08:48 AM
#28
I have zero experience removing the front's, I may still have the originals. I can see from your photo though, the bolts pushing on the rotor seem to be pushing on one side only, which will cock the rotor. Is there a way to push from both sides evenly? Or, put pressure on the one side and then back off a bit while tapping on the opposite side? Too much pressure will on just one side will lock it in place. Also, I've had really good luck with Kroil. It makes stuff like PB blaster and WD40 look like glue. Good luck............
04-13-2018, 10:00 AM
#29
Thanks for your advice artictraveller. I thought the same about pushing the disk using the caliper mount bolt holes. I have tightened the bolts, hit with a BFH and then rotated the rotor 180 degrees and done the same. I can just make out the hairline joint between the rotor and the hub. Although I have a big sledge, there is not a lot of room in the front wheel well to swing it. Not wanting to go sown in defeat this weekend, I bought a puller from Amazon. I also saw a video of someone using a grinder to cut a slot part way through the rotor and then using a chisel to split it. I wonder how long that took!
04-13-2018, 10:41 AM
#30
Wow, it sounds like those are really stuck on there. I suppose as a CA resident I lack those experiences. Mine came off with a tap from a rubber mallet last time I removed them.
If I was in your situation, I'd use two feet of 2x4 or even 4x4 (dimensional lumber, not drive ) hold it up against the caliper and hit the end with a sledge a bunch of times.
