Old 07-23-2007, 07:11 AM   #1
THUD!
Tech's;
We took a trip in our 2005 E350SD 6.0L PSTD SMB RB15 Class "B" motorhome to Indiana July 16-19.
Camped out @ OUABACHE {?Wabash?} State Park near Bluffton.
Dropped the travel trailer and drove to SMB in Huntington.
It was raining on the way back to camp so I was manually downshifting to assist braking on wet pavement.
I noticed a thud [?in the driveline?] upon acceleration, with the transmission manually shifted into low [1st]gear.
This occured while running light {7500LBS} but was not noticed while
towing.
Do We have a problem?
CUL8R;
Ken Kill Sr.
2005 SMB RB15
6.0L PSTD
Torqueshift
Voyager Roof
:q6:
kenkillsr is offline   Reply With Quote
Old 07-23-2007, 02:26 PM   #2
Sounds like something loose in the driveline. Could be normal play or a by product of being in 1st. My transmission handles 1st 2nd and 3rd differently depending on whether I have OD on or off or am in 3rd. If you can reproduce it in D or OD you might consider checking it out. If it's only when manually in 1st you're probably getting a by-product of the transmission profile for that gear... or even just that gear as when you let off the gas a bit instead of smootly going to second since it's forced in first you get instant drag and any play in the driveline comes through as a thunk because the engine drag is effectively reversing the driveline.
This is mostly conjecture as I'm mainly a manual/Jeep guy.
