Old 08-14-2018, 09:28 AM   #1
transmission question
folks,
I am a newbie, and I am sure this will be an esy one for you all. I own a 2011 e350Quigly RB pax van. It has a 5.4 liter gas engine. The transmission is feeling a little soft. what transmission is in the van, and what upgrades should I make when I rebuild it?
Thanks far any help.
mberger67 is offline   Reply With Quote
Old 08-14-2018, 11:11 AM   #2
You might just need some better tuning. Feeling "soft" isn't a symptom of a failing transmission. It just means it's not tuned well for your actual weight. Check out 5-Star tuning.
Old 08-14-2018, 11:21 AM   #3
What exactly does "soft" mean? Is it slow to shift, that's to say the shifts take longer than expected with some slippage between gears? Have you checked the transmission fluid level and fluid condition? It should look clean, not brown with a burned smell.
Old 08-14-2018, 11:30 AM   #4
thanks guys. When I say soft; I mean that the shift is slow and not as crisp as it is when things are cold.
Is this a 5R100 or a 5R110 transmission?
I will check fluid level today and verify color and smell. The van has no leaks that I can see.
Old 08-14-2018, 12:38 PM   #5
Enter the VIN number in a vin decoder online to determine exactly which transmission you have.
Old 08-14-2018, 02:13 PM   #6
5.4L vans have the 4R75.
Old 08-14-2018, 02:17 PM   #7
Is that true for all 5.4s, or just certain years?
Old 08-14-2018, 02:27 PM   #8
2002+. Prior to that some had the 4r100 but maybe not all. 97-99 had the e4od.
TorqueShift only came with the 5.4L in cutaway chassis flavor, never in the vans.
Old 08-14-2018, 04:16 PM   #9
larrie's Avatar
My 2002 has the 4R100.
Larrie
Old 08-14-2018, 04:17 PM   #10
Youngster's Avatar
My 2003 5.4l has a 4r100. Verified by Agile Offroad, they we're a little surprised it was from the factory like that.
Check your VIN to verify, you never know what the assembly line pulled off the shelf...
2016 Beta 500 RS
2014 KTM 350 EXC-F
Youngster is offline   Reply With Quote
The Hulk
Hulk
Bullwinkle
austineats
