Old 01-30-2009, 10:35 PM   #11
outopawn's Avatar
Re: What kind of tire are YOU running?
TOYO Open Country MT 35X12.50R17LT
2006 EB Transformer SMB 4x4 Diesel PH F/R Aluminess SOLD February 2015
2009 EB E350 V10 Quigley - Non-SMB
2005 4x4 Excursion 6.0 Diesel EB Magnaflow Superchip - Bulletproofed
outopawn is offline   Reply With Quote
Old 01-30-2009, 11:11 PM   #12
I have the Toyo Open Country A/T's in LT 285-75 -17. This is a 34" OD with a max load rating of 3970#s. They are E series 10 ply tires. I have been very happy with them. I've had them in snow, mud, dirt, pavement, washboard, etc. oclv
oclv is offline   Reply With Quote
Old 01-31-2009, 08:06 AM   #13
Greg In Austin's Avatar
Originally Posted by oclv
I have the Toyo Open Country A/T's in LT 285-75 -17. ...with a max load rating of 3970#s.
OC,
I can't find Toyo listing the tire you describe....
I find an AT that is 285/70-17 rated at 2833lbs at 35psi
and
I find an MT that is 285/75-17 rated at 3195lbs at 80psi
What am I missing?
Greg in Austin
Old 01-31-2009, 10:02 PM   #14
Originally Posted by Bronco_hauler
Running BFG AT 285/75/16's, E load rated, since last year.
Same size and tire as before, but E load rated versus the previous D rated. More stable ride.
Same as Herb....no problems to date even with the D's. 11.5K + weight since day one. E's were not available during the construction.
Old 02-01-2009, 10:19 AM   #15
There was an article on "Choosing Tires: The Five Step Program" in the May 2008 Off-Road Adventures magazine. I think this is the 4-Wheel Parts magazine.
Step 1 : Tread Rightly (tread choice)
Step 2 : Load Rating (load rating choice)
Step 3 : Size Does Matter (size for height and traction choice)
Step 4 : Wheel Rightly (matching to wheels)
Step 5 : Let's Be Practical Here (expense)
There is also a nice diagram of all the significant measurements and attributes for wheels.
I have saved the article and will scan it and uploaded if it is desired.
Greg in Austin
Old 02-01-2009, 11:13 AM   #16
Angel's Avatar
Greg,
My tires read: Toyo AT Open Country LT285/70R17 Max Load 3750 lbs. @ 80 psi cold
Angel
2000 Isuzu Rodeo V6 4WD
2006 Chalet LTW 15ft. Folding Travel Trailer 14 in. tires
Angel is offline   Reply With Quote
Old 02-01-2009, 12:19 PM   #17
What is up with that?
That seems like Toyo is changing the ratings, that is two or three different sets of stats for what seems like the same tire.... unless it is somehow not the same tire...
Is Toyo the actuall manufacturer? or are they selling tires that are made by others?
Angel, Can you find your tire on the Toyo website?
Greg in Austin
Old 02-01-2009, 12:57 PM   #18
Angel's Avatar
Greg,
Yes. I see the spec pdf you are looking at. You need to look on page 30. The tires that OCTV and I have are under "specialty" (not "P-Metric/Metric")
Angel
Old 02-01-2009, 11:05 PM   #19
My tires are still listed on the Toyo website. The Product code seems to have been changed, but all the specs are the same. I chose the LT 285-75-R17 because for a while there was discussion as to which tires were better, 33" or 35". This size was 34" so I figured I would be right in the middle. Also, with a 410 rear end, I could go to 356 gearing and be right back to exactly the equivilent of 410 with the new 34" tires. oclv
Old 06-29-2009, 12:52 PM   #20
lobo_q3a's Avatar
Send a message via AIM to lobo_q3a
thanks greg
here's a link to that article:
http://www.offroadadventures.com/articles/view/id/263
lobo_q3a is offline   Reply With Quote
