Re: All my screws are pulling loose!
Geoff,
I have had a few screws on cabinet hinges strip out and I use an old carpentry technique to repair them. Here is the process. Get a piece of oak dowel, I usually use either 1/4 or 3/8". Drill out the stripped hole with the same size drill bit as the dowel you are using. Be careful not to drill all the way through the cabinet if the other side shows. Cut a short section of dowel and glue it into the hole. Once the glue has dried re-install the hinge. Oak is hard and you will need to drill a small pilot hole for the screw. It is very simple and will make a permanent repair.
I use the goop on screws that aren't stripped as a preventative measure. It seems to work well for this but hasn't worked for repaired screws that are stripped.
Cheers,
John
