Old 12-22-2016, 03:18 AM   #151
DosMars's Avatar
I just traded a couple of aluminum deck plates I found on a dive recently for a used Espar D2 heater a buddy of mine had that had been used as a boat heater. I need to get it in to be serviced. I'm in Long Beach. Lots of boats and trucks around the harbor that are using these units but the closest service location I've been able to find is in Fontana. I'd love to find something closers for service and install if anyone could point me in the right direction?
Also, from the manual and discussion I've seen in this thread it looks like these units are designed to be mounted inside. If it were housed properly would there be any issues with mounting it externally and ducting the heated air into the Van? I like the peace of mind that if a leak in the exhaust line ever popped up it wouldn't affect us inside.
Thanks for any input, looking forward to some warm nights this winter!
DosMars is offline   Reply With Quote
Old 12-22-2016, 06:40 AM   #152
Bbasso's Avatar
If it's mounted properly you won't have issues with exhaust leaks, especially into the cabin. I installed mine over a year ago with no prior experience and it's been great.
Don't deviate from the directions and you'll be fine.
As I type from my very warm (72 deg) rig despite the outside temps last night being 46.
Rob.
Current:
And had three other E350s...
Old 12-22-2016, 09:20 AM   #153
Flux's Avatar
If you have any sort of inside heating or cooking device you should have a CO alarm regardless.
But yeah, the exhaust and intake is all external. You shouldn't have an issue is installed correctly.
Old 01-17-2017, 03:43 AM   #154
DosMars's Avatar
What about noise reduction by mounting externally? In one maintenance video I watched the unit sounded pretty loud at startup. Doe's the heater kicking on at night wake you up?
I like being cozy but I like my sleep too..
Old 01-17-2017, 09:00 AM   #155
bigriver's Avatar
I installed ours last Fall and think it is fantastic. I found a spot for it under the couch in our 50 plan and it purrs along on cold nights without being a distraction. These heaters are quite loud when they first fire up but will quiet down as the fan moderates to adjust output. The exhaust is quite loud outside the rig at this time as well but we added a muffler which cut that noise down considerably. We don't hear any exhaust noise inside the van.
I agree with Bbasso - install as directed and you shouldn't have any complaints.
Joe
Joe
2003 EB50 7.3L PSD Q4X4
2003 EB30 - Sold
Old 08-01-2017, 03:37 PM   #156
Bbasso's Avatar
Thanks for heads up about the air intake. Mine is routed down then up then down again to prevent anything from getting in and if it does it hopefully will get stuck in the bend going up... so it seems to work well because nearly two years have gone by and D4 is still working great.
Rob.
Current:
Old 10-29-2017, 12:46 PM   #157
help
so been trying to start my furnace
keeps shutting off after about 5-10 min, and is blowing good hot air
display shows "no flame detected"
and my exhaust is full of diesel????
any thoughts
tj4861 is offline   Reply With Quote
Old 10-29-2017, 01:14 PM   #158
Marcel Huijser's Avatar
Try unplugging wires, wait a bit, and then plug them in again. Harness with plug should be behind heater inside van.
Marcel Huijser is offline   Reply With Quote
Old 10-29-2017, 06:30 PM   #159
Turns out my fuel supply line had touched the exshust and melted it. So I had diesil spraying out and running down my exhaust and fresh air supply amkingnit smoke to hell.
Easy fix back on the road just in time for winter
Old 10-29-2017, 07:53 PM   #160
Thank god you didn't catch fire.
