Re: Ford Van: Flooring Replacement Ideas?
one thing to consider - depending upon the type of cabinets you have at floor level, even the thinnest of extra floor covering may prevent you from opening a cupboard door. My floor is carpeted but the prior owner cut some kind of rubber mat to fit over the carpet in the aisle whcih is much easier to clean. Unfortunately, even though it is only a millimeter or 2 thick, if it dislocated to either side by even a little bit, it rides up and prevents doors from opening. By the end of my second day camping in the van, I had folded it in half to get it out of the way. I'll either pull the carpet or anchor the rubber mat so that it cannot move and ride up.
1994 5.4l E250 sportsmobile van, 2WD w/ 4" lift and larger tires.
