Old 07-14-2015, 10:15 PM   #11
rallypanam's Avatar
Re: gray water tank vent done broke
Originally Posted by daveb
can you cut it high enough to slide a no hub over it and rebuild the rest?
The T you can see in the 2nd photo and the broken 90 from the first photo abut one another.. Just a close nipple. So no room. But if could burn the broken piece off, all I need to do is throw on a new 90. So that's the plan. Next week.
Old 07-15-2015, 12:58 AM   #12
BajaSportsmobile's Avatar
Robb,
Cut the broken tee off with a saw just above the glue joint, then cut down through the outer portion of the tee in several places. Use a small wood chisel to chip away the pieces. A heat gun will help with this. I have had to do this many times with ABS pipe like you have - not much of a problem.
AgileOffRoad.com
Old 08-26-2016, 08:05 PM   #13
rallypanam's Avatar
And a mere 13+ months later, it's fixed!
Figured out the fitting was screwed into gray water tank, but had to cut off all the plumbing to be able to unscrew... Did that, replaced with all new plumbing, seems like it might work!
