Old 11-20-2017, 11:34 AM   #21
Originally Posted by dhally View Post
For the shurflo pump, does it prime itself OK? Usually they would be pulling from the bottom of a tank.
If I'm just swapping supply tanks then no problem. I find I have to provide a little help to get the pump to prime sometimes; like after it has been winterized and there is zero water in the lines/pump.
Then a bit of gravity assist sometimes works (holding the supply tank up). Worse case I've blown into the supply line to get water into the pump or sucked on the water spigot. If you were the squeamish type a quick blast with the portable air compressor would do it too.
Pritikin is offline   Reply With Quote
Old 11-21-2017, 08:10 AM   #22
Originally Posted by LastBlackE350 View Post
Link me up Scotty!
Is this the gowesty pump you're using?
Pump, H2O inside tank (submersible) | GoWesty
And fold down faucet? (not Fawcett like I typed below )
Complete Faucet Upgrade Kit | GoWesty
Lots of butcher block style counter tops on eBay right now, Home Depot has em and so does Lumber Liquidators.
Yes, that's the pump and faucet. They are perfect if all you need is a cold water sink.
Dhally, I never heard mine rattle around at all in my Westy but usually I had some water in the tank. I'll be doing this mod very soon with an Aquatainer right behind the driver's seat in a cabinet. I'll report back about noise.
I got this stove from this seller, but one caveat. It did NOT come with a regulator. It should be simple to source, or perhaps the seller can provide one.
I'm borrowing one from another stove I have.
I paid $250 shipped, about half what I could buy the same stove for here in the U.S.
SMEV Dometic 8821 R/H 1 Burner Hob & Sink Combination Unit Cooker | eBay
Old 11-21-2017, 03:37 PM   #23
LastBlackE350's Avatar
Thanks Scotty, couple more questions...
Does the GoWesty faucet upgrade work with your eBay UK sourced SMEV hob? And, how long did shipping from the UK take?
LastBlackE350 is offline   Reply With Quote
Old 11-21-2017, 07:31 PM   #24
Shipping was quick. I did not mount the faucet in the sink yet but I think it will be fine. If I have to fabricate a plate for the faucet mount I'm ok with that, meaning if the hole is too big.
I'm leaving town tomorrow for the holiday but can check it out this weekend when I get back. Feel free to PM me and remind me if I don't remember to update this thread.
