Old 08-31-2008, 01:31 PM   #11
I would like to have an external outside hook up maybe under the van or at the side but it would require temp control at the shower head. Possible?
Dave
Old 04-14-2013, 02:28 PM   #12
Re:
Originally Posted by DUKCSUN
Hey, does anybody have experience with removing the "older model" shower assembly and installing the newer version? From what I can tell the newer shower assembly is superior and I would consider tackling it but only if someone else hasn't exposed some issues with it.
Obviously the fittings are different and the holes are different, I'm just wondering if anyone's tackled it.
The post above mentions that someone has tried it but I did a search and came up with nothing.
Thanks in advance.
Bump. I also have the older Attwood 4131-4 shower wand system. The wand is broken and the hot water valve is bad. For $82 it's a moderately reasonable (by SMB standards ) plug and play replacement http://www.amazon.com/Attwood-4131-4-Ma ... dmarine-20
but I'm wondering if anyone has found the wand separately since the valve is a rather easy fix and/or had luck replacing it with the newer system. From the looks of it you might be left with a bigger hole (ie., square vs rectangular).
What a great resource this forum is
2011 VW TDI Golf for hwy fun
Old 04-14-2013, 08:41 PM   #13
Re: Rear Shower Valves
My rear wand is one of those. They works OK. Maybe if there was a tempering valve it wouldn't be so hard to adjust the heat. Also it's slightly difficult to get the water out of it when your done. As long as it's pointed up it won't drip
Old 04-15-2013, 08:04 AM   #14
BrianW's Avatar
Here's a better direct link to the one shower noted above (Sagiv). I've been thinking of adding one of these inside the rear doors of my van.
http://www.sagiv.com/main.asp?article_i ... Caravan-RV
Does anyone know where they can be purchased in the US? I'm not finding anything with a web search.
Old 04-15-2013, 08:39 AM   #15
charlie56's Avatar
Adventure Trailers has them on their website for $98.
http://www.adventuretrailers.com/accshower.html
... Charlie
KZ6T
Old 04-15-2013, 08:56 AM   #16
BrianW's Avatar
Thanks!
Old 04-16-2013, 08:30 AM   #17
yvrr's Avatar
Re:
Thanks in advance.
Yes, we did:
http://www.sportsmobileforum.com/vie...1&hilit=shower
Jack
'01 Ford EB50p Quigley 4WD
Old 04-16-2013, 03:12 PM   #18
Re: Re:
Thanks in advance.
Yes, we did:
Awesome fix. I'm not sure how I missed that using the search function. I went ahead and bought an Attwood so it'll be a plug and play operation but maybe someone will have the Sagiv version at the Overland Expo that I can check out for future reference.
The Yeti
TexGX
Otter
