Originally Posted by larrie
The curve is the largest of the portables, by a couple of important inches. Since I've just done a bunch of research on this subject for my current build (and I wasn't able to fit the Curve into my cabinet), I thought it might be helpful to post alternatives:
Thetford 550p
16-1/2h x 15w x 16-1/2d
Shorter/shallower than Curve, with same 5.5g waste capacity, but piston-pump flush.
Dometic 976 series
15-1/4h x 13-1/4w x 15-1/4d
A bit smaller again in all dimensions, 5 gallon capacity, Push-button Flush, and a nice handle on the front that should make it easier to pull out from a low cabinet.
I selected the Dometic since the handle will be a help for my wife and kid to pull it out, although I've built my cabinet to accommodate the 550p as well, since I've had good luck with another Thetford in the past and wanted to have a choice if the Dometic doesn't work out.
