Old 05-10-2022, 07:31 AM   #401
1der's Avatar
Our new batch of Z Awning Brackets is ready
Ford E Series (I will be mailing out beg May 26)
Chevy/GMC (in stock)
Easy order page at www.BlingMyRig.com
Let me know if any questions! thxs!!
Old 05-10-2022, 09:25 AM   #402
Very happy with the door talon, and I can't wait to get the new awning on!
MaineWildlands is offline   Reply With Quote
Old 05-10-2022, 09:40 AM   #403
Are these compatible with my highroof van? Tufport topper.
Thanks,
Max
maxswasser is offline   Reply With Quote
Old 05-29-2022, 04:41 PM   #404
stiggs's Avatar
Send a message via ICQ to stiggs Send a message via AIM to stiggs
Do you still have in stock?
2000 Ford RB30 PH 2WD -- Eagle Rock California
stiggs is offline   Reply With Quote
Old 05-29-2022, 07:33 PM   #405
1der's Avatar
I will be able to ship the new batch starting later this week.
Old 05-29-2022, 07:51 PM   #406
stiggs's Avatar
Cool I bought the used Fiamma off the classifieds it has the metal mounts currently installed and he gave me the drill SMB kit. Will I need the Fiamma mounts or can I drill out and bolt to the existing mounts?
Old 05-30-2022, 07:11 AM   #407
REF
REF's Avatar
Send a message via MSN to REF
Awning Z-Brackets - Next Batch
Ray will also provide you with instructions, but here goes, I saw in the other thread you might be a bit intimidated by the process and are now selling the awning.
The SMB mounts require drilling into the outer skin of the van and use expansion bolts to hold, they are prone to cause stress cracks in the sheet metal, they often fail and pull out, causing more damage in the process, unbolt them from the awning and discard, you don’t have to drill them out, just crank open the awning for access to the bolt inside the case.
The Z brackets attach to the gutter with clamp bolts, no drilling into the van required, they replace the SMB mount altogether.
Remove the old mounts from the awning if they’re attached, measure out for proper install locations on the 2 new rear mounts, open the front door and barn doors to install the front bracket, sits right on the B pillar. Get a friend to help you hang the awning on the Z mounts, position it, crank out the awning, secure the legs, pop your top, open up the windows and screens for access to the back side, mark out your holes, drill out your bolt holes in the aluminum case where they line up with the holes in the brackets, careful not to drill into the awning fabric, bolt and secure the awning to the bracket. Tighten everything. Done.
Old 05-30-2022, 09:05 AM   #408
1der's Avatar
Thxs REF!
Stiggs - I sent you a PM last night. I am in Long Beach for most of this week and I have brackets with me. Ping me if you would like to discuss.
here is a link to our Z Brackets install video:
https://www.blingmyrig.com/pages/ins...wning-brackets
Old 05-31-2022, 12:29 PM   #409
Good day!
I’ll gladly take a set for an ARB awning set up.
I have a tufport top and saw that “El Capitan van”has some on theirs!
I’ll gladly wait for the next run of these brackets!
I should ask first, would you ship to Canada?
h2ohammer is offline   Reply With Quote
Old 05-31-2022, 02:32 PM   #410
1der's Avatar
Hi h2ohammer, shipping to Canada is fine. You can select Canada for shipping when ordering.
Re: Tufport topper - There may be an issue as I believe the top sits in the gutter and nearly out to the edge. Best is if you can post/send me some pictures looking down the passenger side gutter so I can see the gutter and lip. You can email me via our website contact at www.BlingMyRig.com
re: ARB sets - I only did that for one run. You can buy a full set, use the front and rear brackets and hang on to the middle bracket and hardware in case you want to move to a Fiamma awning in the future.
thxs! Ray
