Ford E350 Sportsmoble Lead Acid to Lithium House & Engine Batteries Litium
Currently have two D4 7 year old house batteries and two lead acid engine batteries would like to change to lithium.
Has anyone changed to Lithium, will my Magnum 2712E Inverter Converter work for lithium, would I need to upgrade system?
I converted mine last year. Fairly easy swap. I used a DC to DC charger and a 100 amp SOK battery. Here are a couple of threads you may find helpful. There are more.
Larrie
As far as the Magnum 2712E Inverter/Charger, yes it should work with what ever lithium battery you purchase. It not only has a generic lithium setup, but also is fully programable, so you should be able to match what ever battery you purchase.
