Old 04-04-2008, 01:06 PM   #1
LA area SMB service.
This was mentioned in another thread, but I wanted to flag it more clearly for owners who might have missed the info.
Bob's Brake and Alignment in Lawndale is an excellent SMB service and repair provider. I've been to them several times and they've done all the service on my van. Ditto for several other SMB owners, so they are becomming quite familiar with the unique needs of the SMB. Ask for Hubert when you call. If you get there early, they can usually get all the work done in the same day. I usually just hang around and work on my laptop inside the van while service is being performed. In fact, that is what I'm doing now. The SMB works pretty well as a mobile office.
R
4141 Redondo Beach Blvd Lawndale CA
(310) 370-1475
Map:
http://maps.yahoo.com/map?q1=4141%20Red ... 1=20491548
2006 SMB 4x4, EB-51, 6.0psd
EMrider is offline   Reply With Quote
Old 04-04-2008, 04:04 PM   #2
stiggs's Avatar
Send a message via ICQ to stiggs Send a message via AIM to stiggs
so do they have wifi too?
2000 Ford RB30 PH 2WD -- Eagle Rock California
stiggs is offline   Reply With Quote
Old 04-04-2008, 04:23 PM   #3
Wifi is one thing they don't offer. I had to use the slow and not always reliable Verizon network.
R
Old 04-04-2008, 07:35 PM   #4
waltsb2002's Avatar
What type of work do you have done there?
2002 Silver EB350 7.3PS Quigley 4x4 Custom plan...The Original Transformer
waltsb2002 is offline   Reply With Quote
Old 04-04-2008, 09:02 PM   #5
They're an Amsoil dealer and I had them do all of my bypass filter switches. Also had them change fluids in front and rear differentials, transfer case and tranny and change fuel/air filter. Ditto coolant. Lube suspension and driveshafts, inspect brake wear and do an alignment. They do suspension work too and in the near future I'll need to have them replace my ball joints. These seem to be wearing fast on late model vans. Nice guys, quality work and fair prices.
R
Old 04-07-2008, 06:01 PM   #6
lobo_q3a's Avatar
Send a message via AIM to lobo_q3a
R[/quote]
pardon my amsoil noobiness but what do the bypass filter switches do?
and thanks for the mechanic hookup. living in Venice i will mos def check them out in the future.
lobo_q3a is offline   Reply With Quote
Old 04-07-2008, 07:43 PM   #7
R
and thanks for the mechanic hookup. living in Venice i will mos def check them out in the future.[/quote]
Mine and a lot of other late model SMB have an Amsoil oil filtration system installed. This system uses two special oil filters, called bypass filters, mounted on the frame of the van near the tranny. So by filter switches, I mean that Hubert has replaced the two bypass filters for me. It is something I could probably do myself, but it is a very messy job and I'm prone to fubaring stuff like that.
I see you're in Venice so he is relatively close to you.
R
Old 04-07-2008, 11:39 PM   #8
lobo_q3a's Avatar
ahhhh, i see. filter switches...switching out the filters. as opposed to switches that one flicks on or off (which is what i thought you were talking about). i, too, have the amsoil setup and there is much i need to learn about it.
thanks for the clarification.
Old 12-11-2008, 02:21 PM   #9
lobo_q3a's Avatar
mechanic in LA update
EMRider
i wanted to thank you for the Bob's Brake And Alignment tip.
Great service. Extremely thorough.
Hubert and Manny were both very helpful.
thanks again!
Old 12-12-2008, 09:19 AM   #10
kinewave's Avatar
Thanks EM. Good to know. I'm in Hollywood, so Lawndale is not too far to go for good service.
06 SMB V-10 E-350 4x4 RB-50
-and a quiver of fiberglass and polyurethane foam.
kinewave is offline   Reply With Quote
