Old 03-08-2018, 07:36 PM   #111
Have you tried resetting the inertia switch (passenger side footwell)?
Old 03-09-2018, 06:09 PM   #112
I tried pushing it in but it seems like it’s already engaged... I guess it would be up if it was set off... also when I push down on it there’s no give at all... just a solid button...
Checked my fuse 8 in dash.
Also fuse that’s a 30 amp under hood . Both look good. Might test for ohms on those and also check relay
AmboRambo is offline   Reply With Quote
Old 03-13-2018, 11:50 AM   #113
Took it to a shop to be diagnosed
Old 03-13-2018, 10:33 PM   #114
Alright here’s a little update.
It’s running now. According to the shop.
I asked them to diagnose for 105$ let me know what’s wrong and what to do to fix it. Gave some info to them ... They replaced or installed two missing fuses ??? And said the stem or up pipe inside the fuel bowl had been broken and was blocking fuel to the injectors. They pressure tested it and saw that it was getting 60psi ..
I’ll believe them just because it’s running now . Was charged 300$ . Either way I have the van back.
Old 03-19-2018, 01:26 PM   #115
bet on black's Avatar
how frustrating!
'99 ford e350 - 7.3L 4x4
'10 ford f150 raptor scab
'53 buick special eight - the sled
bet on black is offline   Reply With Quote
Old 03-19-2018, 07:42 PM   #116
MadScience's Avatar
Well, at least it's running now, that has to be a good thing.
I'd ask them which fuses they replaced. That might be important info if there was some underlying cause that blew them that's not yet remedied.
Tags
7.3, e350, ebp, no start
