10-19-2016, 09:25 PM
Rusty washers on SMB top
I just got a look at the roof of my SMB top. The washers are very rusty. I haven't crawled up there with a ladder yet to check their structural integrity but has anyone had an issue with leaks in a similar situation?
I live in SoCal so I haven't had to worry about rain for a while.
[/URL][/IMG]
10-19-2016, 10:34 PM
10-19-2016, 11:15 PM
Originally Posted by daveb
Thanks, I will check it out.
10-20-2016, 07:59 AM
easy enough to replace screws nuts and washers with stainless parts....and use some new butyl.
Since you are in Carlsbad, Marshall's hardware has the fasteners and maybe the butyl; otherwise Mcmaster Carr has the butyl.
10-20-2016, 08:02 AM
Can you post a link to the butyl you used? Mcmaster has so much stuff I couldn't narrow it down so I ordered off Ebay and got what I think is perfect, but I'd love to know what the Mcmaster product is so I can bookmark it. I'm sure their stock is more reliable than an eBay seller.
Thanks
10-20-2016, 08:30 AM
Thanks.
In your experience, are all of the 11 bolts and washers the same diameter and length? I understand that you need to cut them off when complete but what is the minimum length to get through the fiberglass and steel tubing?
I will take one out to measure before buying but jut wondered if anyone had that info.
10-21-2016, 07:40 AM
Originally Posted by LandVan
Thanks.
The ones holding the wooden lift blocks are longer than the ones holding the tie-down hooks.......
I can't remember lengths, although the SMB ones are cut off/shortened.
I ended up using longer screws from the bottom up on the front block; those screws also hold two of my solar panels.
10-21-2016, 07:42 AM
Thanks
Pretty sure I used the 1 1/2" general purpose......comes in 50' rolls.
The 2" rolls are 25'.....I think the furring strips on the top are 2"...
McMaster-Carr
10-21-2016, 09:22 AM
Awesome, thanks. I have been curious for awhile. I think I paid a good bit less for it on eBay but, like I said, I trust Mcmaster Carr to have the right part at the needed time and that's not the case for any eBay seller.
10-24-2016, 04:05 PM
Having just recently replace all the bolts, washers, nuts and sealing components on my SMB PH I think I recommend an upgrade to the original waterproofing method. I used butyl caulk (not Home Depot "butyl" added) from Graingers. You will see the brand and type in the picture. I fabricated butyl washers with a hole saw. The sheet butyl came from Amazon https://www.amazon.com/Durometer-Smo.../dp/B000MAL0K2. I lightly applied butyl sealant to both sides of the butyl washers during installation. Everthing else was from McMaster Carr. Good luck.
1999 E350 V-10 Quigley 4X4
