Old 07-20-2016, 07:27 PM   #1
ranchero's Avatar
SMB floor construction question
I just picked up a 2006 SMB RB50 E350. I'm about to rip into the floor to install an Espar D2. I'm not sure what is under the carpet. Does SMB put a plywood floor down? or other insulation? I'm wondering how far down I need to go to get to sheetmetal. TIA
Steve
ranchero is offline   Reply With Quote
Old 07-22-2016, 07:50 AM   #2
In my 95 SMB they had only plywood and then carpet. I couldn't believe the floor had no more insulation. Sorry I can't answer for your 06 but I would sure hope there is a layer of some sort of insulation there as well.
Can you open up the rear doors and pull the trim piece/threshold that runs across? It should give you a good view of what's stacked up from the sheet metal there.
Old 07-23-2016, 03:33 AM   #3
Pntyrmvr's Avatar
Originally Posted by 86Scotty View Post
In my 95 SMB they had only plywood and then carpet. I couldn't believe the floor had no more insulation. Sorry I can't answer for your 06 but I would sure hope there is a layer of...
SMB builds as cheap as possible for warm weather use. 1/2 inch plywood on the steel floor is a thermal break and has an R rating of 0.62. Good enough. The upper walls are canvas in most cases. Did you expect more?
Old 07-23-2016, 10:30 AM   #4
For the money they charge for a new one, which by the way I would never buy, I would expect more. Lots more!
Old 07-25-2016, 09:16 AM   #5
ranchero's Avatar
Thanks guys. Looks like 1/2" plywood and no insulation. We'll see how that works for winter living at 7000 feet.
1990 Syncro Westy
XPCamper/NIMBL on 2007 Ram3500.
A few Cruisers
2006 E350 RB-31 MG Metalworks/UJOR 4x4 swap (on to another)
Old 07-25-2016, 10:14 PM   #6
larrie's Avatar
You are going to need sheepskin slippers to stand on the floor in winter, guaranteed.
Larrie
Old 07-26-2016, 08:19 PM   #7
Old 07-28-2016, 09:05 PM   #8
Sportsmobile will build however you want it. I had them put engine driven rear heat/ac and insulation in the floor with the hot pipes from the engine going down the middle of the floor. My floor is nice and warm when I step down with my bare feet.
Now if I can only find a way to do "auto start on hi/lo temp" with my Promaster.
2015 Promaster Sportsmobile
KB2ZE
Old retired IBM Engineer
DCHitt is offline   Reply With Quote
