Old 01-08-2015, 11:30 PM   #11
REF
REF's Avatar
Send a message via MSN to REF
Stupid Question From a New Owner
Uh....just to clarify-when referring to "black" or "gray" water tanks, it is not referring to the physical color of the tank itself, rather, it refers to what goes in them....."gray" being sink/shower water, "black", well, you get the idea.
Old 01-08-2015, 11:48 PM   #12
ANZAC's Avatar
Re: Stupid Question From a New Owner
Originally Posted by REF
Uh....just to clarify-when referring to "black" or "gray" water tanks, it is not referring to the physical color of the tank itself, rather, it refers to what goes in them....."gray" being waste water, "black", well, you get the idea.
To be more specific: "gray water"=sink/shower/bath drain, "black water"=crapper.
Sportsmobile-less.
Old 01-09-2015, 11:55 AM   #13
REF
REF's Avatar
Fixed, thanks for the clarification
Old 01-09-2015, 02:01 PM   #14
I know that the actual color of the tank plastic doesn't matter, but I only have the one tank that everything empties into. Am I supposed to have 2 tanks?
Old 01-09-2015, 08:00 PM   #15
Typically the gray water tank is separate from the black tank. My gray tank is in the wall under the sink. It also has a drain valve threaded for a discharge using a garden type hose... nothing like what a true black water tank has. Not saying you can't push sink water into a waste water tank along with...
Old 01-09-2015, 08:30 PM   #16
Thanks, Dave. I only have one drain, like your gray tank does. I have a Macerator on mine, so everything gets pulverized small enough to go through a garden hose.
Old 01-12-2015, 10:46 AM   #17
ctb
ctb's Avatar
Send a message via AIM to ctb
Is it correct to state that you only have a black water tank if you have a flushing toilet right? Otherwise yo would only have a gray tank for the sink….AND, small garden hose type release drain (with handle) for gray, larger that shop van hose outlet (with handle) for black...
'13 MDX 'BigBlackmobeebs'
'01 Lexus 430 LS 'Luxobeebs
'20 Tacoma TRD OR 'Tacobeebs'
