10-13-2022, 12:05 PM
Two-Way (CB?) Radio, Emergency Setup?
Hello SMB forum
I have a Ford E-250 2001 RB-50, and I am clueless about how to best ask this question.
Goal: I want to upgrade this van with:
- two-way communication with handheld units (distance short distance, 2-5 miles)
- two-way communication in off-road emergencies
- monitor emergency broadcasts
- antenna, mounted or magnetic
Recommendations?
FYI: I recently passed FCC Technician License; however, this requested goal has to be simple & accessible to my spouse & others who will not have the FCC Technician permissions to handle additional operational complexity.
Thank you, much appreciated.
Jeff in Seattle
2001 Ford E-250 RB50
10-13-2022, 01:16 PM
Simplest is to go with a GMRS radio. Still requires a license, but there's no test just a fee.
Handheld lower power versions are FRS radios, more powerful vehicle mounted radios are GMRS.
I have a Ham radio on my Bronco, but it rarely gets used since not many people have licenses.
10-13-2022, 01:21 PM
Yep can use frs but for emergency - can get a 2m or dual band and program in 2m 146.520 for national calling and local repeaters. Can show a couple people how to use for emergency if needed. As you know emergency use does not require a license.
10-13-2022, 04:32 PM
I am not a radio expert, but I keep one of these in the glovebox just in case. Aside from monitoring channels, I have never used it (in part because I've never traveled with another person or group using one).
I also carry a satellite communicator (Garmin inReach Mini) on our adventures. I figure that if SHTF, I'm much more likely to be able to reach someone or send an SOS with this than a radio.
10-13-2022, 04:57 PM
I am also a Ham operator. This is what have that works very well for me.
Install a mobile unit dual band 2m/70cm. this will give you the flexibility to communicate with other users on GMRS/FRS handheld off-the-shelf units. It will also give you the ability to hit local repeaters that require a Ham license and you can also broadcast on a much higher wattage.
I would recommend installing a 1/2 wave antenna. I mounted mine on the front hood (bracket mounts under the hood on the fender and pokes through the crack between the hood and fender. This gives me a permanent mobile base station with antenna that can communicate with other radios.
I also have a CB. This is not as effective in terms of range but in the woods (think logging trucks) and on the highway, there are many more users and it is much better for connecting with other random people for general info and can be better for emergencies. Feel free to send me a PM if you want details on my setup.
______________________________
2001 E-350 V10 EB50 Penthouse
4.56 gears w/ARB Rear Locker
4X4 Quigley
Agile RIP
10-13-2022, 05:57 PM
Recommendations for specific makes & models for GMRS?
Thank you
Jeff in Seattle
10-13-2022, 06:00 PM
What about Two-way non-emergency usage recommendations?
Thank you
Jeff in Seattle
10-13-2022, 06:02 PM
Clarify
the "two-way communication with handheld units (distance short distance, 2-5 miles)"
is specifically for non-FCC-licensed users and not specifically for emergencies.
Thank you
Jeff in Seattle
10-13-2022, 06:42 PM
Thank you
I have both a vehicle mounted (Micro Mobile), and handheld, radios from Midland.
Seem to be good quality, and you can buy units of different power depending on your range requirements.
https://midlandusa.com/
10-13-2022, 07:57 PM
I’m in the middle of the 4wheeler magazine overland trip. A gmrs was required and the sponsor Midland made it easy to get one. I got a 50watt chassis mounted unit as did many others. We are in a group of at least 27 rigs and the leader is narrating historical sites as we go. The radios are really good and we are spread out a couple miles in some cases. Midland is taking our category really seriously. I’d take a look at the mxt575 or mxt 500. Super easy install and very well made. My 2 cents as a new user.
