Old 03-02-2011, 12:15 AM   #31
TroySmith80's Avatar
Re: What is a good air compressor?
So an engine-belt driven compressor isn't really a viable option in a van? Maybe an A/C compressor or something?
For Sale: 1992 E-350 EB 4x4 High-Top
TroySmith80 is offline   Reply With Quote
Old 03-02-2011, 06:36 AM   #32
What's wrong with DC again?
Old 03-02-2011, 08:29 AM   #33
Oops, that's not very clear. I meant air-conditioning, not alternating-current. I'm just thinking that a 100% duty cycle and HI POWER option run from the engine's serpentine belt would be ideal, as long as it physically fits and is not terribly expensive.
Old 03-02-2011, 08:42 AM   #34
scatter's Avatar
An engine, belt driven, compressor is an ideal way to go. Be sure to have a cutting torch on hand to cut out part of the frame, fenders, etc to get it to fit in....
If you can fit one into an SMB, more power to you.
Scatter
2007 RB50, 6.0
K1WGB
Old 03-02-2011, 08:50 AM   #35
Oh, bummer.
I don't have one of these vans yet, so i can't check myself. But is there anywhere between the transmission and the transfer case, where there is a driveline that is spinning visibly?
If so, could you put the T-case in neutral and machine a pulley to fit onto that shaft, and drive a compressor there with the parking brake set and the transmission in D? Of course, that's assuming that there's room there for a compressor, which there probably isn't.
It's just a bummer to have a monster power source and not be able to use it and have to put up with puny little compressors (or spend a fortune for the nicer ones which are still half the CFM).
Old 03-02-2011, 11:28 AM   #36
To me the CO2 Power Tank has so many advantages.
Quick fill up, portability (does not need to be solid mounted) and good distance out of a tank.
Downfalls. You can run out of CO2.
Cost of purchase. ...All the good set-ups will cost us a chunk of change.
You have a $75K + van, how can you cheap out on air???
As with propane canisters, with CO2 you/I will have to determine refill requirements.
Some of the times posted for airing up tires is just crazy slow.
I am not that patient!
I haven't yet, but I plan to go Power Tank.
I haven't heard of problems too much from owners.
Only non owner nay sayers speaking the negatives.
maxacceleration is offline   Reply With Quote
Old 03-02-2011, 12:06 PM   #37
What's that tiny blower coming out of your van hood?
Oh, that? That's just my OBA setup.
Old 03-05-2011, 05:30 AM   #38
I am running extreme air on all 4 of my rigs.and yes my SMB too. With air tank on 3 of them I have trying them it's the only one that will do every thing I want to do.
Chimneyman is offline   Reply With Quote
Hercules
firedude67
Campervan
Joerg
