Originally Posted by macmcintire
I've actually never changed a tire in my life because every flat I've had has happened directly in front of a tire store or mechanic's shop. However, the other day I told my wife that I had just realized that if I ever did get a flat on my rig while alone out in the boonies I wouldn't have the strength to change my tire alone. So my HiLift jack is just a hood ornament.
My 2 cents.
Unless its a sidewall blowout, I would not change the tire at all. That's why I carry an ARB plug kit for. Only had to use it one time but it was a cinch. Put enough air in the tire using your on-board compressor till you find the leak, plug it and re-fill the tire right on the ground. No Jack, no mess. No having to lift that 35-incher up on the Aluminess tire carrier.
