Old 03-02-2014, 08:14 PM   #1
Ford aux switches
I am trying to get ready for a trip. In doing so I need power to the rear of the van. Where do u tie into the aux switches. I looked under the hood and there is a blank 4 pin connector, there was also a 4 pin plug in the console laying loose. Trying to determine if I plug in the loose plug somewhere of use the piece under hood.
bdyer is offline   Reply With Quote
Old 03-02-2014, 08:40 PM   #2
Re: Ford aux switches
Under the hood. There is a passthrough harness to bring the circuits back inside through the firewall. The pass-through the 4-pin connector near the blunt-cut wires below the cowling, and the other end is near the steering column.
Here's the switch info:
https://www.fleet.ford.com/truckbbas/non-html/Q174.pdf
Old 03-02-2014, 08:40 PM   #3
Here's more wiring info:
https://www.fleet.ford.com/truckbbas...ml/Q171_R1.pdf
Old 03-02-2014, 08:56 PM   #4
