Old 08-25-2013, 08:52 PM   #1
Pschitt's Avatar
Which tire chain for 35/12.5 R 17 ?
I did a search but didn't find much about that.
Does some of you have experience with tire chain on 35/12.5 R 17 tires? I would like a "diamond design" and if possible a model to install without having to move the vehicule.
Any advice will be appreciatied. Thanks! ;-)
Claude-Alain
Old 08-25-2013, 09:45 PM   #2
Silver350's Avatar
Re: Which tire chain for 35/12.5 R 17 ?
Originally Posted by Pschitt
.....and if possible a model to install without having to move the vehicule.
Claude-Alain
Wouldn't we all. Other than air operated "automatic chains" for commercial vehicles, I think you're out of luck.
The key to chaining up efficiently is to put them away properly, ie. not tangled and turned inside out.
"there is neither science nor fact prevailing here" - vlamgat
Silver350 is offline   Reply With Quote
Old 08-25-2013, 11:40 PM   #3
E350's Avatar
IMO, CAM locks:
viewtopic.php?f=3&t=7655&start=30
Old 08-26-2013, 05:31 AM   #4
Pschitt's Avatar
I don't think so, they are many chains you can mount without moving the vehicle in Europe. But maybe not here?
Thanks E350. I saw that post but these chains at not "diamond", which is much better to steer the vehicle.
Any other experience?
Old 08-26-2013, 09:07 AM   #5
E350's Avatar
Here you go:
Their ratchet system would seem to obviate the need for CAM locks (which is the only way to not have a floppy chain on regular transverse chains IMO). Although I haven't had to order chains for years, I have purchased at least two sets of V-Bar with CAM locks from Tirechain.com and they were simply superb to deal with.
But this is what they warn about diamond chains:
"DIAMOND QUICK FIT
featured in Outdoor Explorer Magazine:
Most popular choice for light truck tire chains. Diamond tire chain insures a smooth ride with less vibration and noise. Maximum traction insures minimal brake distance and skidding. D-Link pattern Links for extended life and traction. Available in both a heavy duty 4.5 mm cross chain a type SAE CLASS "S" for restricted clearance requirements. Exclusive Ratchet Tensioner for quick installation and removal. Comes with a zippered storage case>. Not recommended for off-road, mud, plowing, diesel, or heavy duty trucks."
http://tirechain.com/16INCHTRUCKCHAINS.HTM
I have a diesel. It is a heavy vehicle. I have no doubt that I would wear through the center chain quickly in California where they require you to put chains on with a hint of snow. (That is unless you have 4x4 and M/S rated tires, which I do, so I no longer use chains. BTW as also stated in the thread cited above, with 4x4 I much prefer studded snow tires over chains. That said, there is nothing as close to a tractor than a diesel SMB in 4x4 low with chains. YRMV.)
Old 08-26-2013, 09:31 PM   #6
Pschitt's Avatar
Thank you very much for the tip E350. I only need chains for deep snow, not for mud or rock crowling, so it should be fine.
Old 08-27-2013, 08:33 PM   #7
Silver350's Avatar
That ratchet tightening system has a rubber strap incorporated into it. What's
the advantage of a chain and ratchet if there's a bungy cord at the other end?
Old 08-27-2013, 11:09 PM   #8
E350's Avatar
Good eye Silver350. I think you have a point. I hate anything rubber on tire chains. They don't hold the chain tight and let the chain hit and damage the fender.
That's why I love CAM locks, I have gotten them so tight I was afraid I might pop the tire! No slop whatsoever!
Old 10-06-2013, 08:47 PM   #9
rltilley's Avatar
I've used chains with rubber pieces built into them & I ruined two pairs just by tightening them by hand. I won't buy another set that has rubber anywhere on them.
rltilley is offline   Reply With Quote
