Old 11-22-2015, 10:46 AM   #1
Power steering fluid or ATF?
I was going to top off my power steering fluid and according to the cap it says "power steering fluid" but the fluid inside is pink like dex/mere type Automatice Transmission Fluid. I have an 07 e350 v10. Can someone point me in the right direction? I ruined a power steering pump once putting the wrong stuff in once so I'm really gun shy, leaving for a trip in two days. Thanks for any help!
C.
Old 11-23-2015, 01:08 PM   #2
Re: Power steering fluid or ATF?
Maybe I should rephrase the question:
Do you use power steering fluid or ATF in your power steering fluid in your rig?
Old 11-23-2015, 01:22 PM   #3
yes, power steering fluid = Mercon-V for Fords starting with the Triton motors. That's what I use.
I think Ford started re-branding to prevent confusion, because you cannot use the newer ATFs like LV or SP for power steering. Looks like there's still some of the old-branded bottles out there:
http://www.amazon.com/Ford-XT-5-5QM-.../dp/B000NU67V8
Old 11-24-2015, 10:25 AM   #4
Carringb! You rock thanks!!!!
