Old 10-12-2012, 01:16 PM   #1
265/75R/16 BFG AT KOs on E150
While anxiously waiting for my 2nd 2wd van from SMB wondering about tires on the E150 as last time (in 2000) i got a E350. I need to keep stock lift, but want to put the subject tires on Dick Cepek DC2 wheels which have a -12mm offset. With this tire/wheel set up, the van is lifted to 6'11", which is perfect, need to keep it under 7'. I am replacing stock front bumper with a trojan bumper, so that rub is gone. I am thinking I am going to have to rubber mallet the inside wheel well an inch or two to avoid the rub on either side?? The -12mm offset should help some?
Steve
surfvane150 is offline   Reply With Quote
Old 11-06-2012, 10:13 AM   #2
Re: 265/75R/16 BFG AT KOs on E150
Steve, did you ever install this setup? I am about to go 265/75/16 on my stock E350 and wondering how many issues I run into. I am not too concerned about minor rub at full lock, but any insights you have for me would be appreciated!
joearlo is offline   Reply With Quote
Old 07-16-2013, 12:00 AM   #3
Best tire size for vans into opinion is 235 85r16 1" narrower than 265 but same overall diameter. All are e-rated and they are cheaper too. We have them on our 04 e350 super duty diesel and love them.
dieselcruiserhead is offline   Reply With Quote
Old 10-23-2013, 06:10 AM   #4
I just put 265/75 16's , Hankook Dynapro atm, E rated, on my 2013 E150 stock steel rims.
No rubbing issues front or back and no rubbing at full lock.
They look great and the van rides much better.
pawel is offline   Reply With Quote
Old 07-01-2020, 07:39 AM   #5
Ok so not for nothing but the r is for rim and belongs with the last number 75" rim's would be atrocious
Tkelly143 is offline   Reply With Quote
Old 07-03-2020, 08:17 AM   #6
Originally Posted by Tkelly143 View Post
Ok so not for nothing but the "r" is for rim and belongs with the last number 75" rim's would be atrocious
Actually the "R" is for radial, as opposed to bias ply tires from long ago. The designation you seem to be mocking is a name of sorts, so if we/you/they have multiples the the apostrophe "s" is appropriate.
The correct phrase showing more than one would indeed be "265/65-R16's"
Jim Bridger
wander
SilVan
dhally
