Old 10-30-2015, 12:11 AM   #1
2012 RB 5.4L 9k miles, 2WD (New and very custom) Now $115K
Though this looks like a Sportsmobile it is far from it. This rig was designed by me and assembled by craftsmen; it’s a one-off and was not produced on an assembly line of marginally skilled labor. It is one-of-a-kind and a work of art. Every single person that’s seen it and understands quality of design and build is blown away. If you’re looking for a new, unique, and super trick rig, this is the one. I’m selling it because I finished building it 2 years ago and it just sits in my driveway. Given my work schedule is not likely to change for next 2 years I’m gonna sell it as it simply makes me sad to see it sitting unused. The low miles are 99% freeway. I’ve camped in it like 4 times. Basically it’s flawless.
2012 E25 RB 5.4L 2X with tow and power package (9,300 original miles)
“RB 50” style
SMB Penthouse pop-top (manual) Completely overhauled as I wasn’t happy with the SMB construction. Top was removed, re-insulated, re-sheeted w/ ¼” marine ply, quality felt liner, added improved stainless bolts/nuts
Bamboo cabinets, drawers, and countertop. Built by cabinet makers. No MDF and L-bracket junk. Bamboo is light, beautiful, and very hard
Action Van 6” lift (their Ultimate System)
Steering stabilizer (Bilstein), fender flares, and steps
4.10 Limited slip differential (Dana)
Deaver leaf springs (custom)
Fox Shocks (custom)
Nitto Terra Grappler Tires 285/75R 16
Wheels American Racing AR23
Solar panels - 2 - 140 watt Kyocera
Fiamma awning 10’ with custom mounting brackets
Awning also has chassis mounting points for legs (not on sheet metal)
Golight spotlight on roof w/ cockpit control
Suburban 5 gal hot water heater
Truckfridge 4.2 cu. ft. 12v
Propex heater with thermostat (HS2800 w/ 9,700 BTU) behind driver seat
Stove - SMEV 8000 2-burner w/ lid
25 gallon fresh water holding tank
Insulated stainless sink with pullout faucet
GE 2-stage water filter under sink
Microwave
Charge controller
Inverter panel
LED touch to click on lights throughout
Inverter - Xantrax 2000w Pure Sine
7 gal Manchester propane tank
4 gal gray water holding tank (mounted under rig to save storage behind cabinets)
2 AGM Batteries stradling under floor storage box (where spare used to be)
Front buckets swivel and electric heat
Upholstery Ultraleather (synthetic) throughout
Dynamat throughout floor and sidewalls
Extra insulation in floor and sidewalls
Floor also has ½” foam/vinyl (MLV) covered in Lonseal rubber floor
½” Marine grade plywood under Lonseal
Alarm - Encore E9 2-way
JVC head unit
JL Audio XD600/6 (600 watt amp)
JL 8” Sub
5 - Kenwood Excelon 6” x 8” speakers
Custom Tweeters in A-pillars of doors
Starlights exterior motion porch lights w/ LED bulbs X2
Tinted windows
Fire extinguisher
SureFlo water pump
Full set of tools, recovery kit, VIAR compressor, water hose, outdoor carpet, etc.
This rig is turn-key with everything you can possibly imagine. Add gas and yourself for adventure.
JimHefner is offline   Reply With Quote
Old 10-30-2015, 12:12 AM   #2
Re: 2012 RB 5.4L 9k miles, 2X $124,000 (new and very custom
More
Cabinet layout w fridge.JPG   Countertop, sink, galley.JPG   Back interio storage and platform.JPG
Old 10-30-2015, 12:13 AM   #3
more
Old 10-30-2015, 12:14 AM   #4
more
Old 10-30-2015, 12:16 AM   #5
more
Sink, charging, microwave.JPG   Propex heater and amp.JPG   Xantrax inverter.JPG
Old 10-30-2015, 12:17 AM   #6
more
Propane and sidestep.JPG   Storage and 4D bats.JPG   Water storage under bench.JPG
Old 10-30-2015, 12:18 AM   #7
more
Beanch seat.JPG   View forward lookng from back.JPG   Water pump and 12V terminals.JPG
Old 10-30-2015, 12:19 AM   #8
more
Subwoofer and fuses.JPG   Water heater storage interior.JPG   Water heater external.JPG
Old 10-30-2015, 12:21 AM   #9
more
Old 10-30-2015, 12:22 AM   #10
more
Malbec
brushogger
MCSporty
MSD
