Old 05-26-2009, 11:06 PM   #1
1987 FORD E-250 4X4 FOR SALE (MOVED due to continuing discus
I have a 1987 Ford E250 Van for sale. It has Fords 300 Inline 6 cylinder EFI engine that was rebuilt several years ago that runs like a top. It has a C-6 tranny with a heavy duty (hard shifting) shift kit with no problems. It also has a P 205 transfer case and 4:11 gears. It has a Dana 44 front axle with warn locking hubs and a Dana 60 rear posi axle. There are no issues with any of the suspension or running gear and all components were checked about three years ago when the 4:11 gears and new shocks were installed. It has 33 X 12.50 tires and 16.5 X 10 or 10.50 wheels (can't remember how wide the wheels are?) with 8 lugs. The tires have only about 2000 miles on them. The van also has a towing hitch in the stock Ford bumper. The van is pretty much stripped on the inside except for a headliner, two front seats and two removeable rear bench seats (all with seat belts). This was an old fed ex van and was converted to 4 wheel drive in 1987 for Fed Ex by Transaxle of Colorado Inc. Trailmaster All Wheel Drive. Of which I have the original Altered Vehicle Certification Build Sheet. The 4 X 4 "system" is very good. I had intended on converting the van into a camping vehicle so I changed out all the solid rear doors to doors with windows and installed a tinted original Ford flip out passenger window just behind the drivers side door. From the outside the window looks stock, from the inside you can see where the welded . Nate 530 318 1582 $4,500
n8ludwig is offline   Reply With Quote
Old 05-27-2009, 01:11 AM   #2
Re: 1987 FORD E-250 4X4 FOR SALE
Very cool. How about a bunch more pics?
Old 06-12-2009, 02:47 PM   #3
OK $4000.00
Old 09-30-2009, 09:37 PM   #4
Zaskoda's Avatar
What kind of fuel economy are you getting with that inline 6?
Zaskoda is offline   Reply With Quote
Old 10-01-2009, 12:14 AM   #5
15 mph city.....19 highway at 55-60mph....on the van now are 33 x 12.50 so with a more narrow tire those would change...
Old 10-17-2009, 06:39 PM   #6
Zaskoda's Avatar
I've been reading up on that engine tonight and am very surprised. It looks like Ford's biggest inline 6. Apparently that engine was used in dump trucks and tractors. I just gave you a call. I'm pretty far away so taking for a test drive is a challenge... but this might be exactly what I'm looking for. =)
Old 10-17-2009, 10:32 PM   #7
Most of the used SMBs purchased through this forum were purchased without a test drive. Am I right gentlemen?
CharlyBaltimore is offline   Reply With Quote
Old 10-18-2009, 01:32 PM   #8
Well, it makes negoations difficult when the seller knows you just drove 17 hours to come see the van and it's not quite as advertised...
Old 10-18-2009, 02:19 PM   #9
Are you speaking from personal experience?
Old 10-18-2009, 05:33 PM   #10
Gotta read way back:
viewtopic.php?f=8&t=142
(And as usual I didn't verify my numbers! )
Betsy
darryldickie
My Van
bfolens
