Old 06-12-2007, 06:59 PM   #1
Penthouse weight
I plan to carry six pedal bikes, 4 kayaks and 4 surf boards on the roof of the PH.
How much weight can be lifted on the rood with the manual PH top?
Will I have to remove the gear to lift the PH?
Your feedback is much appreciated.
1999 Ford E-350, Quigley 4wd conversion, 7.3 L Powerstroke Diesel
oldgoat is offline   Reply With Quote
Old 06-12-2007, 07:31 PM   #2
Jeffrey's Avatar
You need a bigger truck.
Old 06-12-2007, 07:38 PM   #3
Plan to carry or plan to fit?
You should contact SMB, I'm sure they have the best info on extreme loading...
Old 06-12-2007, 10:02 PM   #4
Scalf77's Avatar
I believe it is 300lbs for the Electric PH top, I think the springs could be adjust on the Manual top to about 75 – 80lbs, without removing what was on the roof rack. But that was over 4 years ago that I asked that question.
Old 06-13-2007, 08:42 AM   #5
SM says I need the electric PH however users usually know best. Thanks for the info.
