I'm wondering what this thing is worth in this condition?
Or rather what someone would pay for it?
https://www.instagram.com/p/BIvjPmSA...e_cheney&hl=en
The good:
underside of the floor pans little rust
no visible rust on the roof - exterior paint shaded by a tree
window configuration that suits me
7.3 Power stroke w/no car Faxable problem history
Borg Warner T-case Ok condion
4 under carage to chassis box beam bushings in good shape
Owned by a fellow snowboarder Mtn Biker (like me) - so mutual reputations at stake should something go wrong.
The bad:
Advanced 4x4 conv - hard to source part info
T-case actuator hard to work with
Rust on:
Exhaust manifold
Many fasteners on things like the water pump and oil pan that would have to be drilled out
Front box beams, front suspension & wheelwells etc are where the rust - looks like not fresh water wash-down after short trips East of WA
Aluminum Alternator even rusty
Heavy custom steel bumpers and door steps welded to Box beams -
Need to be removed because it's adding weight to the spring loads
and adding rust to the box beams locally
