Airing Up With Air Compressor
A lot of people seem to be over reacting to the diesel idling issue.
Idling it once in a while is normal and won't hurt your engine, even if it's not high idled. The negative effects of not high idling on a regular basis are cumulative but understand, idling your vehicle an hour or two here and there will not hurt it. Idling it for 3-4 hours a day, every day (fleet type use, think parked ambulance), will cause problems without the high idle.
