Reviving this thread to add some relevant information.
I had the rear drive shifter detach on my Atlas twin stick transfer case. I was going to rebuild but the bushings in the parts spec shown above in this thread have been discontinued. There are two options: You can drill it out the bores and use a larger bushing that Advance Adapters does carry or instead do a retrofit with a heim joint. The upgrade kit is $70 but will have less play and shifter rattle which was an issue in the past. The upgrade kit here: https://www.advanceadapters.com/atla...int-kit-3-8-34
2011 VW TDI Golf for hwy fun
